Аналоги реле Phoenix Contact, Finder, Omron, ABB, Schneider
Datasheet Linear Technology LTC3411A — Даташит
СерияLTC3411A
1.25A, 4MHz, Synchronous Step-Down DC/DC Converter
Datasheet LTC3411A
PDF, 1.5 Мб, Язык: анг., Файл закачен: 21 сен 2017, Страниц: 22
AliExpress
Оригинальные MSOP10 LTC3411AEMS LTAJK ltc3411aim LTAJK LTC3411EMS LTQT LTC3411IMS LTQT LTC3411 LTC3411A LTC3411AE 3411,
230 ₽
LTC3411A: 2.5-5.5Vin [email protected]
Электромеханические реле Hongfa – надежность и качество 19 января 2023
LTC3411AEDD#PBFLTC3411AEDD#TRPBFLTC3411AEMS#PBFLTC3411AEMS#TRPBFLTC3411AIDD#PBFLTC3411AIDD#TRPBFLTC3411AIMS#PBFLTC3411AIMS#TRPBF
N12345678
Корпус3x3 DFN-10
Габаритный чертеж корпуса
3x3 DFN-10
MS-10
MS-10
3x3 DFN-10
3x3 DFN-10
MS-10
MS-10
Код корпусаDDDDMSMSDDDDMSMS
Индекс корпуса05-08-169905-08-169905-08-166105-08-166105-08-169905-08-169905-08-166105-08-1661
Количество выводов1010101010101010
Parameters / ModelsLTC3411AEDD#PBFLTC3411AEDD#TRPBFLTC3411AEMS#PBFLTC3411AEMS#TRPBFLTC3411AIDD#PBFLTC3411AIDD#TRPBFLTC3411AIMS#PBFLTC3411AIMS#TRPBF
АрхитектураConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current ModeConstant Frequency Current Mode
Demo BoardsDC1176ADC1176ADC1176ADC1176ADC1176ADC1176ADC1176ADC1176A
Design ToolsLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD FileLTspice File,LTpowerCAD File
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиBurst Mode, External Synchronization, Resistor Set Frequency, Power Good, 100% Duty CycleBurst Mode, External Synchronization, Resistor Set Frequency, Power Good, 100% Duty CycleBurst Mode, External Synchronization, Resistor Set Frequency, Power Good, 100% Duty CycleBurst Mode, External Synchronization, Resistor Set Frequency, Power Good, 100% Duty CycleBurst Mode, External Synchronization, Resistor Set Frequency, Power Good, 100% Duty CycleBurst Mode, External Synchronization, Resistor Set Frequency, Power Good, 100% Duty CycleBurst Mode, External Synchronization, Resistor Set Frequency, Power Good, 100% Duty CycleBurst Mode, External Synchronization, Resistor Set Frequency, Power Good, 100% Duty Cycle
Тактовая частота, kHz40004000400040004000400040004000
Frequency Adjust RangeUp to 4MHzUp to 4MHzUp to 4MHzUp to 4MHzUp to 4MHzUp to 4MHzUp to 4MHzUp to 4MHz
Frequency Sync Range400kHz to 4MHz400kHz to 4MHz400kHz to 4MHz400kHz to 4MHz400kHz to 4MHz400kHz to 4MHz400kHz to 4MHz400kHz to 4MHz
Integrated Inductorнетнетнетнетнетнетнетнет
Ishutdown, мкА0.10.10.10.10.10.10.10.1
Isupply, мА0.040.040.040.040.040.040.040.04
Max Phases11111111
Monolithicдададададададада
Количество выходов11111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A1.251.251.251.251.251.251.251.25
Polyphaseнетнетнетнетнетнетнетнет
Switch Current, A2.12.12.12.12.12.12.12.1
Synchronousдададададададада
TopologyBuckBuckBuckBuckBuckBuckBuckBuck
Vin Max, В5.55.55.55.55.55.55.55.5
Vin Min, В2.52.52.52.52.52.52.52.5
Vout Max, В5.55.55.55.55.55.55.55.5
Vout MaximumVinVinVinVinVinVinVinVin
Vout Min, В0.80.80.80.80.80.80.80.8
Vref Accuracy Over Temp, %22222222
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Power Management > Switching Regulator > Step-Down (Buck) Regulators > Micropower Buck Regulators | Internal Power Switch Buck
На английском языке: Datasheet Linear Technology LTC3411A
Публикации по теме
