Datasheet Linear Technology LTC1622CMS8#TRPBF — Даташит
Серия | LTC1622 |
Модель | LTC1622CMS8#TRPBF |
Low Input Voltage Current Mode Step-Down DC/DC Controller
Datasheet LTC1622
PDF, 198 Кб, Язык: анг., Файл закачен: 20 сен 2017, Страниц: 16
Купить LTC1622CMS8#TRPBF на РадиоЛоцман.Цены — от 102 до 232 ₽ 15 предложений от 12 поставщиков Buck Regulator Positive Output Step-Down DC-DC Controller IC 8-MSOP | |||
LTC1622CMS8#TRPBF Analog Devices | от 102 ₽ | ||
LTC1622CMS8#TRPBF Analog Devices | 165 ₽ | ||
LTC1622CMS8#TRPBF | по запросу | ||
LTC1622CMS8#TRPBF Linear Technology | по запросу |
Корпус | MS-8 |
Код корпуса | MS8 |
Индекс корпуса | 05-08-1660 |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC232A |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Основные особенности | 100% Duty Cycle |
Тактовая частота | 550 kHz |
Integrated Inductor | нет |
Ishutdown | 4 мкА |
Isupply | 0.27 мА |
Max Phases | 1 |
Monolithic | нет |
Количество выходов | 1 |
Рабочий диапазон температур | от 0 до 70 °C |
Выходной ток | 5 A |
Polyphase | нет |
Sense Resistor | Rsense |
Switch Current | 5 A |
Synchronous | нет |
Topology | Buck |
Vin Max | 9.8 В |
Vin Min | 2 В |
Vout Max | 9.8 В |
Vout Maximum | Vin |
Vout Min | 0.8 В |
Vref Accuracy Over Temp | 1.9 % |
- Linear Technology Magazine Circuit Collection, Volume IV &mdash AN84PDF, 2.4 Мб, Файл опубликован: 1 апр 2000
Application Note 84 is a collection of "power circuits" from the years 1996 through 1998 as seen in the pages of Linear Technology magazine. This Application Note collects circuits that can output tens of amps to circuits that can operate a handheld device for several years. In addition to a wide variety of traditional power supply circuits (Buck, Boost, Inverting, Flyback, Linear Regulators, etc.) we include circuits for charging batteries, several Power Management circuits as well as circuits that highlight a very low noise switching regulator.Выписка из документа
Design Notes
- Low Dropout 550kHz DC/DC Controller Operates from Inputs as Low as 2V &mdash DN208PDF, 88 Кб, Файл опубликован: 2 июл 1999Выписка из документа
Статьи
- LTC1622: Low Input Voltage, Current Mode PWM Buck Converter &mdash LT JournalPDF, 245 Кб, Файл опубликован: 1 ноя 1998Выписка из документа
- Using Current Sensing Resistors with Hot Swap Controllers and Current Mode Voltage Regulators &mdash LT JournalPDF, 142 Кб, Файл опубликован: 1 сен 2003Выписка из документа
Серия: LTC1622 (6)
- LTC1622CMS8#PBF LTC1622CMS8#TRPBF LTC1622CS8#PBF LTC1622CS8#TRPBF LTC1622IS8#PBF LTC1622IS8#TRPBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > External Power Switch Buck Controllers
LTC1622CMS8TRPBF, LTC1622CMS8 TRPBF
