Datasheet Linear Technology LTC1174HVIS8#TRPBF — Даташит
Серия | LTC1174HV |
Модель | LTC1174HVIS8#TRPBF |
High Efficiency Step-Down and Inverting DC/DC Converter
Datasheet LTC1174, LTC1174-3.3, LTC1174-5
PDF, 263 Кб, Язык: анг., Файл закачен: 20 сен 2017, Страниц: 20
Купить LTC1174HVIS8#TRPBF на РадиоЛоцман.Цены — от 372 до 502 ₽ 17 предложений от 11 поставщиков Buck, Buck-Boost Switching Regulator IC Positive or Negative Adjustable 1.25V 1 Output 340mA, 600mA 8-SOIC (0.154, 3.90mm Width) | |||
LTC1174HVIS8#TRPBF Analog Devices | 372 ₽ | ||
LTC1174HVIS8#TRPBF Linear Technology | 460 ₽ | ||
LTC1174HVIS8#TRPBF Analog Devices | от 493 ₽ | ||
LTC1174HVIS8#TRPBF | по запросу |
Корпус | SO-8 |
Код корпуса | S8 |
Индекс корпуса | 05-08-1610 (S8) |
Архитектура | Constant Off-Time Current Mode |
Demo Boards | DC059A-A,DC059A-B,DC059A-C |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Основные особенности | Fixed Output |
Тактовая частота | 200 kHz |
Integrated Inductor | нет |
Ishutdown | 1 мкА |
Isupply | 0.13 мА |
Max Phases | 1 |
Monolithic | да |
Количество выходов | 1 |
Выходной ток | 0.432 A |
Polyphase | нет |
Switch Current | 0.6 A |
Synchronous | нет |
Topology | Buck, Inverting |
Vin Max | 18.5 В |
Vin Min | 4 В |
Vout Max | 18 В |
Vout Maximum | 0.70Vin |
Vout Min | 1.25 В |
Vref Accuracy Over Temp | 4 % |
Vswitch Max | 18.5 В |
- Linear Technology Magazine Circuit Collection, Volume II &mdash AN66PDF, 1.1 Мб, Файл опубликован: 1 авг 1996
Application Note 66 is a compendium of "power circuits" from the first five years of Linear Technology. This application note contains circuits that can power most any system you can imagine, from desktop computer systems to micropower systems for portable and handheld equipment. Also included here are circuits that provide 300W or more of power factor corrected DC from a universal input. Battery chargers are included, some that charge several battery types, some that are optimized to charge a single type. MOSFET drivers, high side switches and H-bridge driver circuits are also included, as is an article on simple thermal analysis.Выписка из документа
Design Notes
- A Simple High Efficiency, Step-Down Switching Regulator &mdash DN73PDF, 78 Кб, Файл опубликован: 1 авг 1993Выписка из документа
- Techniques for Deriving 3.3V from 5V Supplies &mdash DN74PDF, 73 Кб, Файл опубликован: 1 сен 1993Выписка из документа
- Ultra-Low Power, High Efficiency DC/DC Converter Operates Outside the Audio Band &mdash DN86PDF, 73 Кб, Файл опубликован: 1 сен 1994Выписка из документа
- 5V to 3.3V Circuit Collection &mdash DN91PDF, 74 Кб, Файл опубликован: 1 ноя 1994Выписка из документа
Серия: LTC1174HV (11)
- Power Management > Switching Regulator > Inverting Regulators
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck
LTC1174HVIS8TRPBF, LTC1174HVIS8 TRPBF
