Datasheet Linear Technology LT8640IUDC#PBF — Даташит
Серия | LT8640 |
Модель | LT8640IUDC#PBF |
42V, 5A Synchronous Step-Down Silent Switcher with 2.5µA Quiescent Current
LT8640/LT8640-1: 42V, 5A Synchronous Step-Down Silent Switcher with 2.5µA Quiescent Current Data Sheet
PDF, 1.7 Мб, Файл закачен: 27 мар 2018
Купить LT8640IUDC#PBF на РадиоЛоцман.Цены — от 369 до 2 108 ₽ 32 предложений от 16 поставщиков LINEAR TECHNOLOGY LT8640IUDC#PBF DC-DC Switching Step Down Regulator, Adjustable, 3.4V-42Vin, 970mV-41.9Vout, 5Aout, QFN-18 | |||
LT8640IUDC-1#PBF Analog Devices | 369 ₽ | ||
LT8640IUDC#PBF Analog Devices | от 470 ₽ | ||
LT8640IUDC-1#PBF Analog Devices | от 710 ₽ | ||
LT8640IUDC#TRPBF Linear Technology | по запросу |
Корпус | 3x4 QFN-18 |
Код корпуса | UDC |
Индекс корпуса | 05-08-1956 |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC2202A |
Design Tools | LTspice File,LTpowerCAD File |
Экспортный контроль | нет |
Основные особенности | Low EMI, Silent Switcher Architecture, Resistor Set Frequency, External Synchronization, Burst Mode, Tracking, Power Good |
Тактовая частота | 3000 kHz |
Frequency Adjust Range | 200kHz - 3MHz |
Frequency Sync Range | 200kHz - 3MHz |
Integrated Inductor | нет |
Ishutdown | 0.75 мкА |
Isupply | 0.0017 мА |
Max Phases | 1 |
Monolithic | да |
Количество выходов | 1 |
Выходной ток | 5 A |
Polyphase | нет |
Switch Current | 10 A |
Synchronous | да |
Topology | Buck |
Vin Max | 42 В |
Vin Min | 3.4 В |
Vout Max | 41.58 В |
Vout Maximum | 0.99Vin |
Vout Min | 0.97 В |
Vref Accuracy Over Temp | 1.23 % |
Серия: LT8640 (6)
- LT8640EUDC#PBF LT8640EUDC#TRPBF LT8640HUDC#PBF LT8640HUDC#TRPBF LT8640IUDC#PBF LT8640IUDC#TRPBF
- Power Management > Switching Regulator > Ultralow Noise Regulators
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Micropower Buck Regulators | Internal Power Switch Buck | High Input Voltage Buck
LT8640IUDCPBF, LT8640IUDC PBF
