Datasheet Linear Technology LT3990IDD#TRPBF — Даташит
Серия | LT3990 |
Модель | LT3990IDD#TRPBF |
62V, 350mA Step-Down Regulator with 2.5µA Quiescent Current and Integrated Diodes
Datasheet LT3990, LT3990-3.3, LT3990-5
PDF, 307 Кб, Язык: анг., Файл закачен: 19 сен 2017, Страниц: 22
62V, 350mA Step-Down Regulator with 2.5μA Quiescent Current and Integrated Diodes
Купить LT3990IDD#TRPBF на РадиоЛоцман.Цены — от 255 до 1 258 ₽ 22 предложений от 12 поставщиков Buck Switching Regulator IC Positive Adjustable 1.21V 1 Output 350mA 10-WFDFN Exposed Pad | |||
LT3990IDD#TRPBF Analog Devices | 255 ₽ | ||
LT3990IDD#TRPBF Linear Technology | 423 ₽ | ||
LT3990IDD TRPBF Linear Technology | по запросу | ||
LT3990IDD#TRPBF Analog Devices | по запросу |
Корпус | 3x3 DFN-10 |
Код корпуса | DD |
Индекс корпуса | 05-08-1699 |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC1471A |
Design Tools | LTspice File,LTpowerCAD Model |
Экспортный контроль | нет |
Основные особенности | Burst Mode, Resistor Set Frequency, Power Good |
Тактовая частота | 2200 kHz |
Frequency Adjust Range | 200kHz - 2.2MHz |
Integrated Inductor | нет |
Ishutdown | 0.7 мкА |
Isupply | 0.0017 мА |
Max Phases | 1 |
Monolithic | да |
Количество выходов | 1 |
Выходной ток | 0.35 A |
Polyphase | нет |
Switch Current | 0.7 A |
Synchronous | нет |
Topology | Buck |
Vin Max | 60 В |
Vin Min | 4 В |
Vout Max | 25 В |
Vout Maximum | 25V |
Vout Min | 1.21 В |
Vref Accuracy Over Temp | 2.1 % |
Серия: LT3990 (22)
- LT3990EDD#PBF LT3990EDD#TRPBF LT3990EMSE#PBF LT3990EMSE#TRPBF LT3990EMSE-3.3#PBF LT3990EMSE-3.3#TRPBF LT3990EMSE-5#PBF LT3990EMSE-5#TRPBF LT3990HMSE#PBF LT3990HMSE#TRPBF LT3990HMSE-3.3#PBF LT3990HMSE-3.3#TRPBF LT3990HMSE-5#PBF LT3990HMSE-5#TRPBF LT3990IDD#PBF LT3990IDD#TRPBF LT3990IMSE#PBF LT3990IMSE#TRPBF LT3990IMSE-3.3#PBF LT3990IMSE-3.3#TRPBF LT3990IMSE-5#PBF LT3990IMSE-5#TRPBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Micropower Buck Regulators | Internal Power Switch Buck | High Input Voltage Buck
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
LT3990IDDTRPBF, LT3990IDD TRPBF
