Datasheet Linear Technology LT3695 — Даташит
Серия | LT3695 |
1A Fault Tolerant Micropower Step-Down Regulator
Datasheet LT3695
PDF, 508 Кб, Язык: анг., Файл закачен: 19 сен 2017, Страниц: 30
Купить LT3695 на РадиоЛоцман.Цены — от 285 до 1 439 ₽ 32 предложений от 20 поставщиков Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 1A 16-TFSOP (0.118, 3.00mm Width) Exposed Pad | |||
LT3695EMSE#PBF Analog Devices | 285 ₽ | ||
LT3695EMSE#TRPBF Linear Technology | 351 ₽ | ||
LT3695EMSE#TRPBF Linear Technology | 354 ₽ | ||
LT3695EMSE#PBF Analog Devices | по запросу |
Parameters / Models | LT3695EMSE#PBF | LT3695EMSE#TRPBF | LT3695EMSE-3.3#PBF | LT3695EMSE-3.3#TRPBF | LT3695EMSE-5#PBF | LT3695EMSE-5#TRPBF | LT3695HMSE#PBF | LT3695HMSE#TRPBF | LT3695HMSE-3.3#PBF | LT3695HMSE-3.3#TRPBF | LT3695HMSE-5#PBF | LT3695HMSE-5#TRPBF | LT3695IMSE#PBF | LT3695IMSE#TRPBF | LT3695IMSE-3.3#PBF | LT3695IMSE-3.3#TRPBF | LT3695IMSE-5#PBF | LT3695IMSE-5#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B | DC1519A,DC1578A-A,DC1578A-B |
Design Tools | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good | Burst Mode, Resistor Set Frequency, External Synchronization, Power Good |
Тактовая частота, kHz | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 | 2200 |
Frequency Adjust Range | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz | 250kHz - 2.2MHz |
Frequency Sync Range | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz | 300kHz - 2.2MHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 |
Isupply, мА | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 | 0.075 |
Max Phases | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Monolithic | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Выходной ток, A | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Over Voltage Protection, В | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
Polyphase | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Switch Current, A | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 |
Synchronous | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Topology | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck | Buck |
Vin Max, В | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 |
Vin Min, В | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 |
Vout Max, В | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Vout Maximum | 20V | 20V | 20V | 20V | 20V | 20V | 20V | 20V | 20V | 20V | 20V | 20V | 20V | 20V | 20V | 20V | 20V | 20V |
Vout Min, В | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
Vref Accuracy Over Temp, % | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 | 1.875 |
LT3695EMSE#PBF | LT3695EMSE#TRPBF | LT3695EMSE-3.3#PBF | LT3695EMSE-3.3#TRPBF | LT3695EMSE-5#PBF | LT3695EMSE-5#TRPBF | LT3695HMSE#PBF | LT3695HMSE#TRPBF | LT3695HMSE-3.3#PBF | LT3695HMSE-3.3#TRPBF | LT3695HMSE-5#PBF | LT3695HMSE-5#TRPBF | LT3695IMSE#PBF | LT3695IMSE#TRPBF | LT3695IMSE-3.3#PBF | LT3695IMSE-3.3#TRPBF | LT3695IMSE-5#PBF | LT3695IMSE-5#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LT3695 (18)
- LT3695EMSE#PBF LT3695EMSE#TRPBF LT3695EMSE-3.3#PBF LT3695EMSE-3.3#TRPBF LT3695EMSE-5#PBF LT3695EMSE-5#TRPBF LT3695HMSE#PBF LT3695HMSE#TRPBF LT3695HMSE-3.3#PBF LT3695HMSE-3.3#TRPBF LT3695HMSE-5#PBF LT3695HMSE-5#TRPBF LT3695IMSE#PBF LT3695IMSE#TRPBF LT3695IMSE-3.3#PBF LT3695IMSE-3.3#TRPBF LT3695IMSE-5#PBF LT3695IMSE-5#TRPBF
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Micropower Buck Regulators | Internal Power Switch Buck
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Switching Regulators
