Datasheet Linear Technology LT3468ES5-1#TRPBF — Даташит
Серия | LT3468-1 |
Модель | LT3468ES5-1#TRPBF |
Photoflash Capacitor Chargers in ThinSOT
LT3468/LT3468-1/LT3468-2 - Photoflash Capacitor Chargers in ThinSOT
PDF, 465 Кб, Версия: A, Файл закачен: 18 сен 2017
Купить LT3468ES5-1#TRPBF на РадиоЛоцман.Цены — от 170 до 406 ₽ 13 предложений от 10 поставщиков Photoflash Capacitor Charger PMIC TSOT-23-5 | |||
LT3468ES5-1#TRPBF Analog Devices | 170 ₽ | ||
LT3468ES5-1#TRPBF Linear Technology | 189 ₽ | ||
LT3468ES5-1#TRPBF Analog Devices | по запросу | ||
Корпус | SOT-23 |
Код корпуса | S5 |
Индекс корпуса | 05-08-1635 |
Demo Boards | DC661A-A,DC661A-B,DC711A-A,DC711A-B,DC711A-C,DC796A |
Design Tools | LTspice File |
Экспортный контроль | нет |
Integrated Inductor | нет |
Ishutdown | 1 мкА |
Isupply | 5 мА |
Monolithic | да |
Количество выходов | 1 |
Рабочий диапазон температур | от 0 до 85 °C |
Polyphase | нет |
Switch Current | 0.55 A |
Synchronous | нет |
Topology | Flyback, Photoflash |
Vin Max | 16 В |
Vin Min | 2.5 В |
- High Voltage, Low Noise, DC/DC Converters &mdash AN118PDF, 2.6 Мб, Файл опубликован: 28 мар 2008
Photomultipliers (PMT), avalanche photodiodes (APD), ultrasonic transducers, capacitance microphones, radiation detectors and similar devices require high voltage, low current bias. Additionally, the high voltage must be pristinely free of noise; well under a millivolt is a common requirement with a few hundred microvolts sometimes necessary. Normally, switching regulator conп¬Ѓgurations cannot achieve this performance level without employing special techniques. One aid to achieving low noise is that load currents rarely exceed 5mA. This freedom permits output п¬Ѓltering methods that are usually impractical.Выписка из документа - Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98PDF, 886 Кб, Файл опубликован: 19 ноя 2004
Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.Выписка из документа
Design Notes
- Basic Flashlamp Illumination Circuitry for Cellular Telephones/Cameras &mdash DN345PDF, 110 Кб, Файл опубликован: 2 сен 2004Выписка из документа
Статьи
- Photoflash Capacitor Chargers Fit into Tight Spots &mdash LT JournalPDF, 379 Кб, Файл опубликован: 1 дек 2003Выписка из документа
Серия: LT3468-1 (2)
- LT3468ES5-1#TRMPBF LT3468ES5-1#TRPBF
- Power Management > Switching Regulator > Xenon Photoflash Charger
LT3468ES5-1TRPBF, LT3468ES5-1 TRPBF, LT3468ES51#TRPBF, LT3468ES5 1#TRPBF
