Datasheet Linear Technology LT1956 — Даташит
Серия | LT1956 |
High Voltage, 1.5A, 500kHz Step-Down Switching Regulators
Datasheet LT1956, LT1956-5
PDF, 316 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 28
Купить LT1956 на РадиоЛоцман.Цены — от 268 до 1 799 ₽ 41 предложений от 25 поставщиков Buck Switching Regulator IC Positive Adjustable 1.219V 1 Output 1.5A (Switch) 16-SSOP (0.154, 3.90mm Width) | |||
LT1956EGN#PBF Analog Devices | 268 ₽ | ||
LT1956IFE#TRPBF Linear Technology | 286 ₽ | ||
LT1956CGN-5 | по запросу | ||
LT1956EGN#PBF Linear Technology | по запросу |
Parameters / Models | LT1956EFE#PBF | LT1956EFE#TRPBF | LT1956EFE-5#PBF | LT1956EFE-5#TRPBF | LT1956EGN#PBF | LT1956EGN#TRPBF | LT1956EGN-5#PBF | LT1956EGN-5#TRPBF | LT1956IFE#PBF | LT1956IFE#TRPBF | LT1956IFE-5#PBF | LT1956IFE-5#TRPBF | LT1956IGN#PBF | LT1956IGN#TRPBF | LT1956IGN-5#PBF | LT1956IGN-5#TRPBF |
Архитектура | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode | Constant Frequency Current Mode |
Demo Boards | DC423B | DC423B | DC423B | DC423B | DC423B | DC423B | DC423B | DC423B | DC423B | DC423B | DC423B | DC423B | DC423B | DC423B | DC423B | DC423B |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization | Fixed Output, External Synchronization |
Тактовая частота, kHz | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 |
Frequency Sync Range | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz | 580kHz - 700kHz |
Integrated Inductor | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ishutdown, мкА | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 | 25 |
Isupply, мА | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
Max Phases | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Monolithic | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Количество выходов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Рабочий диапазон температур, °C | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от 0 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Выходной ток, A | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 |
Polyphase | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Switch Current, A | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Synchronous | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Topology | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting | Buck, Inverting |
Vin Max, В | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
Vin Min, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Vout Max, В | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 | 45 |
Vout Maximum | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN | .75VIN |
Vout Min, В | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 | 1.2 |
Vref Accuracy Over Temp, % | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Vswitch Max, В | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 |
LT1956EFE#PBF | LT1956EFE#TRPBF | LT1956EFE-5#PBF | LT1956EFE-5#TRPBF | LT1956EGN#PBF | LT1956EGN#TRPBF | LT1956EGN-5#PBF | LT1956EGN-5#TRPBF | LT1956IFE#PBF | LT1956IFE#TRPBF | LT1956IFE-5#PBF | LT1956IFE-5#TRPBF | LT1956IGN#PBF | LT1956IGN#TRPBF | LT1956IGN-5#PBF | LT1956IGN-5#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Design Notes
- Efficient Dual Polarity Output Converter Fits into Tight Spaces &mdash DN318PDF, 82 Кб, Файл опубликован: 2 авг 2003Выписка из документа
Статьи
- 60V/3A Step-Down DC/DC Converter Maintains High Efficiency over a Wide Range of Input Voltages &mdash LT JournalPDF, 179 Кб, Файл опубликован: 9 авг 2004Выписка из документа
Серия: LT1956 (16)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck | High Input Voltage Buck
