Datasheet Linear Technology LT1375IS8-5#PBF — Даташит
Серия | LT1375 |
Модель | LT1375IS8-5#PBF |
1.5A, 500kHz Step-Down Switching Regulators
Datasheet LT1375, LT1376
PDF, 518 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 28
Купить LT1375IS8-5#PBF на РадиоЛоцман.Цены — от 336 до 2 478 ₽ 23 предложений от 16 поставщиков Buck, SEPIC Switching Regulator IC Positive Fixed 5V 1 Output 1.5A (Switch) 8-SOIC (0.154, 3.90mm Width) | |||
LT1375IS8-5#PBF Analog Devices | 336 ₽ | ||
LT1375IS8-5#TR Linear Technology | 404 ₽ | ||
LT1375IS8-5 Linear Technology | по запросу | ||
Корпус | SO-8 |
Код корпуса | S8 |
Индекс корпуса | 05-08-1610 (S8) |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC084B-A,DC084B-B |
Design Tools | LTspice File |
Экспортный контроль | нет |
Основные особенности | External Synchronization |
Тактовая частота | 500 kHz |
Frequency Sync Range | 580kHz - 900kHz |
Integrated Inductor | нет |
Ishutdown | 20 мкА |
Isupply | 2.5 мА |
Max Phases | 1 |
Monolithic | да |
Количество выходов | 1 |
Выходной ток | 1.2 A |
Polyphase | нет |
Switch Current | 2 A |
Synchronous | нет |
Topology | Buck |
Vin Max | 25 В |
Vin Min | 5 В |
Vout Max | 21.5 В |
Vout Maximum | .86VIN |
Vout Min | 2.42 В |
Vref Accuracy Over Temp | 2.5 % |
Vswitch Max | 35 В |
LT1375HV LT1376 LT1376 LT1376HV
- Ultracompact LCD Backlight Inverters &mdash AN81PDF, 365 Кб, Файл опубликован: 1 сен 1999
It has become desirable to fashion laptop computers with large area screens, leaving little room for the display's backlight inverter electronics. Miniaturization limitations of high voltage magnetic transformers impose limits on achievable space reduction. Another voltage step-up technology, piezoelectric transformers, permits the desired size reduction and provides additional benefits. This publication describes practical piezoceramic transformers and support circuitry. Ancillary benefits of the piezoelectric approach are also described. Appended sections detail transformer operation and feedback loop considerations.Выписка из документа
Серия: LT1375 (12)
- Power Management > Switching Regulator > SEPIC Regulators
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck
LT1375IS8-5PBF, LT1375IS8-5 PBF, LT1375IS85#PBF, LT1375IS8 5#PBF
