Datasheet Linear Technology LT1372HVIS8#TRPBF — Даташит
Серия | LT1372HV |
Модель | LT1372HVIS8#TRPBF |
500kHz and 1MHz High Efficiency 1.5A Switching Regulators
Datasheet LT1372, LT1377
PDF, 203 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 12
Купить LT1372HVIS8#TRPBF на РадиоЛоцман.Цены — от 368 до 475 ₽ 9 предложений от 9 поставщиков Buck, Boost, Cuk, Flyback, Forward Converter, SEPIC Switching Regulator IC Positive or Negative Adjustable 1.245V 1 Output 1.5A (Switch) 8-SOIC (0.154,... | |||
LT1372HVIS8#TRPBF Analog Devices | 368 ₽ | ||
LT1372HVIS8#TRPBF Linear Technology | 471 ₽ | ||
LT1372HVIS8#TRPBF Linear Technology | 475 ₽ | ||
LT1372HVIS8#TRPBF Analog Devices | по запросу |
Корпус | SO-8 |
Код корпуса | S8 |
Индекс корпуса | 05-08-1610 (S8) |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC053A-A |
Design Tools | LTspice File |
Экспортный контроль | нет |
Основные особенности | External Synchronization |
Тактовая частота | 500 kHz |
Frequency Sync Range | 600kHz - 800kHz |
Integrated Inductor | нет |
Ishutdown | 12 мкА |
Isupply | 4 мА |
Monolithic | да |
Количество выходов | 1 |
Polyphase | нет |
Switch Current | 2 A |
Synchronous | нет |
Topology | Boost, Flyback, Sepic, Inverting |
Vin Max | 30 В |
Vin Min | 2.7 В |
Vin Min Startup | 2.7 В |
Vout Max | 42 В |
Vout Min | 1.245 В |
Vswitch Max | 42 В |
- A Fourth Generation of LCD Backlight Technology &mdash AN65PDF, 5.9 Мб, Файл опубликован: 1 ноя 1995
This publication, LTC's fourth effort devoted to LCD backlighting in as many years, treats the subject comprehensively. The text considers lamps, display and layout induced losses, circuitry, efficiency related issues, optimization and measurement techniques. Twelve appended sections cover lamp types, mechanical design, electrical and photometric measurement, layout, circuitry and related topics.Выписка из документа
Design Notes
- Micropower Buck/Boost Circuits, Part 1: Converting Three Cells to 3.3V* &mdash DN109PDF, 77 Кб, Файл опубликован: 1 авг 1995Выписка из документа
- Micropower Buck/Boost Circuits, Part 2: Converting Four Cells to 5V* &mdash DN110PDF, 133 Кб, Файл опубликован: 1 авг 1988Выписка из документа
- Monolithic DC/DC Converters Break Speed Limits to Shrink Board Space &mdash DN125PDF, 80 Кб, Файл опубликован: 2 мар 1996Выписка из документа
- The LT1370: A 500kHz, 6A Monolithic Boost Converter &mdash DN183PDF, 78 Кб, Файл опубликован: 1 июл 1998Выписка из документа
- Capacitor and EMI Considerations New High Frequency Switching Regulators &mdash DN95PDF, 82 Кб, Файл опубликован: 1 янв 1995Выписка из документа
Серия: LT1372HV (5)
- LT1372HVCN8#PBF LT1372HVCS8#PBF LT1372HVIN8#PBF LT1372HVIS8#PBF LT1372HVIS8#TRPBF
- Power Management > Switching Regulator > Inverting Regulators
- Power Management > Switching Regulator > Step-Up (Boost) Regulators > Internal Power Switch Boost
LT1372HVIS8TRPBF, LT1372HVIS8 TRPBF
