Datasheet Linear Technology LT1171HVIT#PBF — Даташит
Серия | LT1171HV |
Модель | LT1171HVIT#PBF |
100kHz, 5A, 2.5A and 1.25A High Efficiency Switching Regulators
LT1170/LT1171/LT1172 - 100kHz, 5A, 2.5A and 1.25A High Efficiency Switching Regulators
PDF, 339 Кб, Версия: I, Файл закачен: 3 сен 2017
Купить LT1171HVIT#PBF на РадиоЛоцман.Цены — от 537 до 6 746 ₽ 23 предложений от 12 поставщиков Buck, Boost, Cuk, Flyback, Forward Converter Switching Regulator IC Positive or Negative Adjustable 1.244V 1 Output 2.5A (Switch) TO-220-5 | |||
LT1171HVIT#PBF Analog Devices | 537 ₽ | ||
LT1171HVIT Linear Technology | 640 ₽ | ||
LT1171HVIT Linear Technology | от 915 ₽ | ||
LT1171HVIT#PBF Analog Devices | от 6 746 ₽ |
Корпус | TO-220 |
Код корпуса | T |
Индекс корпуса | 05-08-1421 (Std) |
Архитектура | Constant Frequency Current Mode |
Demo Boards | DC139A-A |
Design Tools | LTspice File |
Экспортный контроль | нет |
Основные особенности | External Synchronization |
Тактовая частота | 100 kHz |
Frequency Sync Range | 120kHz - 160kHz |
Integrated Inductor | нет |
Ishutdown | 50 мкА |
Isupply | 6 мА |
Monolithic | да |
Количество выходов | 1 |
Polyphase | нет |
Switch Current | 2.5 A |
Synchronous | нет |
Topology | Boost, Flyback, Sepic |
Vin Max | 60 В |
Vin Min | 3 В |
Vin Min Startup | 3 В |
Vout Max | 60 В |
Vout Min | 1.244 В |
Vswitch Max | 75 В |
LT1170 LT1170HV LT1171 LT1172 LT1172HV
- Power Conditioning for Notebook and Palmtop Systems &mdash AN51PDF, 260 Кб, Файл опубликован: 3 авг 1992
Notebook and palmtop systems need a number of voltages developed from a battery. Competitive solutions require small size, high efficiency and light weight. This publication includes circuits for high efficiency 5V and 3.3V switching and linear regulators, back light display drivers and battery chargers. All the circuits are specifically tailored for the requirements outlined above.Выписка из документа
Design Notes
- Power Supplies for Subscriber Line Interface Circuits &mdash DN130PDF, 78 Кб, Файл опубликован: 2 июн 1996Выписка из документа
- Switching Regulator Allows Alkalines to Replace NiCads &mdash DN41PDF, 70 Кб, Файл опубликован: 1 ноя 1990Выписка из документа
Статьи
- Positive-to-Negative Converter Powers В–48V Telecom Circuits &mdash LT JournalPDF, 230 Кб, Файл опубликован: 1 май 1998Выписка из документа
Серия: LT1171HV (7)
- Power Management > Switching Regulator > SEPIC Regulators
- Power Management > Switching Regulator > Step-Up (Boost) Regulators > Internal Power Switch Boost
LT1171HVITPBF, LT1171HVIT PBF
