Datasheet Linear Technology LT1076IQ#PBF — Даташит
Серия | LT1076 |
Модель | LT1076IQ#PBF |
Step-Down Switching Regulator
Datasheet LT1074, LT1076
PDF, 189 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 16
Купить LT1076IQ#PBF на РадиоЛоцман.Цены — от 329 до 2 573 ₽ 40 предложений от 24 поставщиков Buck, Boost, Flyback Switching Regulator IC Positive or Negative Adjustable 2.5V 1 Output 2A (Switch) TO-263-6, D²Pak (5 Leads + Tab),... | |||
LT1076IQ#PBF Linear Technology | 329 ₽ | ||
LT1076IQ#PBF Analog Devices | 372 ₽ | ||
LT1076IQ#TR Linear Technology | 447 ₽ | ||
LT1076IQ-5 | по запросу |
Корпус | DDPAK-5 |
Код корпуса | Q |
Индекс корпуса | 05-08-1461 |
Архитектура | Constant Frequency Current Mode |
Design Tools | LTspice File |
Экспортный контроль | нет |
Тактовая частота | 100 kHz |
Integrated Inductor | нет |
Ishutdown | 140 мкА |
Isupply | 8.5 мА |
Max Phases | 1 |
Monolithic | да |
Количество выходов | 1 |
Выходной ток | 1.6 A |
Polyphase | нет |
Switch Current | 2.6 A |
Synchronous | нет |
Topology | Buck, Inverting |
Vin Max | 45 В |
Vin Min | 7.3 В |
Vout Max | 35 В |
Vout Maximum | 35V |
Vout Min | 2.21 В |
Vswitch Max | 65 В |
LT1074 LT1074 LT1074HV LT1076HV
- LT1074/LT1076 Design Manual &mdash AN44PDF, 477 Кб, Файл опубликован: 1 сен 1991
This note discusses the use of the LT1074 and LT1076 high efficiency switching regulators. These regulators are specifically designed for ease of use. This application note is intended to eliminate the most common errors that customers make when using switching regulators as well as offering insight into the inner workings of switching designs. There is an entirely new treatment of inductor design based upon simple mathematical formulas that yield direct results. There are extensive tutorial sections devoted to the care and feeding of the Positive Step- Down (Buck) Converter, the Tapped Inductor Buck Converter, the Positive-to-Negative Converter and the Negative Boost Converter. Additionally, many troubleshooting hints are included as well as oscilloscope techniques, soft-start architectures, and micropower shutdown and EMI suppression methods.Выписка из документа
Design Notes
- High Performance Frequency Compensation Gives DC-to-DC Converter 75Вµs Response With High Stability &mdash DN53PDF, 81 Кб, Файл опубликован: 1 окт 1991Выписка из документа
- Low Parts Count DC/DC Converter Circuit With 3.3V and 5V Outputs &mdash DN69PDF, 69 Кб, Файл опубликован: 1 апр 1993Выписка из документа
Серия: LT1076 (14)
- Power Management > Switching Regulator > Inverting Regulators
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > Internal Power Switch Buck | High Input Voltage Buck
LT1076IQPBF, LT1076IQ PBF
