Datasheet Linear Technology LT1074IT7#PBF — Даташит
Серия | LT1074 |
Модель | LT1074IT7#PBF |
Step-Down Switching Regulator
Datasheet LT1074, LT1076
PDF, 189 Кб, Язык: анг., Файл закачен: 3 сен 2017, Страниц: 16
Купить LT1074IT7#PBF на РадиоЛоцман.Цены — от 552 до 3 316 ₽ 31 предложений от 19 поставщиков Buck, Boost, Flyback Switching Regulator IC Positive or Negative Adjustable 2.5V 1 Output 5.5A (Switch) TO-220-7 Formed Leads | |||
LT1074IT7#PBF Analog Devices | 552 ₽ | ||
LT1074IT7 Linear Technology | 637 ₽ | ||
LT1074IT7 Analog Devices | 3 112 ₽ | ||
LT1074IT7 Analog Devices | по запросу |
Корпус | TO-220 |
Код корпуса | T7 |
Индекс корпуса | 05-08-1422 (Std) |
Архитектура | Constant Frequency Current Mode |
Design Tools | LTspice File |
Экспортный контроль | нет |
Тактовая частота | 100 kHz |
Integrated Inductor | нет |
Ishutdown | 140 мкА |
Isupply | 8.5 мА |
Max Phases | 1 |
Monolithic | да |
Количество выходов | 1 |
Выходной ток | 4.4 A |
Polyphase | нет |
Switch Current | 6.5 A |
Synchronous | нет |
Topology | Buck, Inverting |
Vin Max | 45 В |
Vin Min | 7.3 В |
Vout Max | 35 В |
Vout Maximum | .85Vin |
Vout Min | 2.21 В |
Vswitch Max | 65 В |
LT1074HV LT1076 LT1076 LT1076HV
- Step Down Switching Regulators &mdash AN35PDF, 6.2 Мб, Файл опубликован: 1 авг 1989
Discusses the LT1074, an easily applied step-down regulator IC. Basic concepts and circuits are described along with more sophisticated applications. Six appended sections cover LT1074 circuitry detail, inductor and discrete component selection, current measuring techniques, efficiency considerations and other topics.Выписка из документа - LT1074/LT1076 Design Manual &mdash AN44PDF, 477 Кб, Файл опубликован: 1 сен 1991
This note discusses the use of the LT1074 and LT1076 high efficiency switching regulators. These regulators are specifically designed for ease of use. This application note is intended to eliminate the most common errors that customers make when using switching regulators as well as offering insight into the inner workings of switching designs. There is an entirely new treatment of inductor design based upon simple mathematical formulas that yield direct results. There are extensive tutorial sections devoted to the care and feeding of the Positive Step- Down (Buck) Converter, the Tapped Inductor Buck Converter, the Positive-to-Negative Converter and the Negative Boost Converter. Additionally, many troubleshooting hints are included as well as oscilloscope techniques, soft-start architectures, and micropower shutdown and EMI suppression methods.Выписка из документа - Efficiency and Power Characteristics of Switching Regulator Circuits &mdash AN46PDF, 2.6 Мб, Файл опубликован: 1 ноя 1991
Efficiency varies for different DC/DC converters. This application note compares the efficiency characteristics of some of the more popular types. Step-up, step-down, flyback, negative-to-positive, and positive-to-negative are shown. Appended sections discuss how to select the proper aluminum electrolytic capacitor and explain power switch and output diode loss calculations. - Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98PDF, 886 Кб, Файл опубликован: 19 ноя 2004
Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.Выписка из документа
Design Notes
- No Design Switching Regulator 5V, 5A Buck (Step Down) Regulator &mdash DN48PDF, 70 Кб, Файл опубликован: 1 авг 1991Выписка из документа
- No Design Switiching Regulator 5V Buck-Boost (Positive to Negative) Regulator &mdash DN49PDF, 71 Кб, Файл опубликован: 1 сен 1991Выписка из документа
Серия: LT1074 (8)
- Power Management > Switching Regulator > Step-Down (Buck) Regulators > High Input Voltage Buck | Internal Power Switch Buck
- Power Management > Switching Regulator > Inverting Regulators
LT1074IT7PBF, LT1074IT7 PBF
