Datasheet Linear Technology LT1070IT#06PBF — Даташит
Серия | LT1070 |
Модель | LT1070IT#06PBF |
5A and 2.5A High Efficiency Switching Regulators
Datasheet LT1070, LT1071
PDF, 218 Кб, Версия: E, Файл закачен: 3 сен 2017, Страниц: 12
Купить LT1070IT#06PBF на РадиоЛоцман.Цены — от 574 до 966 ₽ 11 предложений от 10 поставщиков Buck, Boost, Cuk, Flyback, Forward Converter Switching Regulator IC Positive or Negative Adjustable 1.25V 1 Output 5A (Switch) TO-220-5 | |||
LT1070IT#06PBF Analog Devices | 574 ₽ | ||
LT1070IT#06PBF Linear Technology | 834 ₽ | ||
LT1070IT#06PBF Linear Technology | от 966 ₽ | ||
LT1070IT#06PBF Linear Technology | по запросу |
Корпус | TO-220 |
Код корпуса | T |
Индекс корпуса | 05-08-1421 (Flow 06) |
Design Tools | LTspice Model |
Экспортный контроль | нет |
Тактовая частота | 40 kHz |
Ishutdown | 100 мкА |
Isupply | 6 мА |
Monolithic | да |
Количество выходов | 1 |
Switch Current | 5 A |
Synchronous | нет |
Topology | Boost, Flyback, Sepic |
Vin Max | 40 В |
Vin Min | 3 В |
Vin Min Startup | 3 В |
Vout Max | 40 В |
Vout Min | 1.244 В |
Vswitch Max | 65 В |
- LT1070 Design Manual &mdash AN19PDF, 656 Кб, Язык: анг., Файл опубликован: 1 июн 1986, Страниц: 80
Application Note 19. This design manual is an extensive discussion of all standard switching configurations for the LT1070; including buck, boost, flyback, forward, inverting and "Cuk." The manual includes comprehensive information on the LT1070, the external components used with it, and complete formulas for calculating component values.Выписка из документа - Switching Regulators for Poets: A Gentle Guide for the Trepidatious &mdash AN25PDF, 359 Кб, Файл опубликован: 2 сен 1987
Subtitled "A Gentle Guide for the Trepidatious," this is a tutorial on switching regulator design. The text assumes no switching regulator design experience, contains no equations, and requires no inductor construction to build the circuits described. Designs detailed include flyback, isolated telecom, off-line, and others. Appended sections cover component considerations, measurement techniques and steps involved in developing a working circuit.Выписка из документа - Some Thoughts on DC-DC Converters &mdash AN29PDF, 1.2 Мб, Файл опубликован: 1 окт 1988
This note examines a wide range of DC/DC converter applications. Single inductor, transformer, and switched-capacitor converter designs are shown. Special topics like low noise, high efficiency, low quiescent current, high voltage, and wide-input voltage range converters are covered. Appended sections explain some fundamental properties of different types of converters.Выписка из документа - Switching Regulator Circuit Collection &mdash AN30PDF, 606 Кб, Файл опубликован: 1 фев 1989
Switching regulators are of universal interest. Linear Technology has made a major effort to address this topic. A catalog of circuits has been compiled so that a design engineer can swiftly determine which converter type is best. This catalog serves as a visual index to be browsed through for a specific or general interest.Выписка из документа - Linear Circuits for Digital Systems &mdash AN31PDF, 1.5 Мб, Файл опубликован: 2 фев 1989
Subtitled "Some Affable Analogs for Digital Devotees," discusses a number of analog circuits useful in predominantly digital systems. VPP generators for flash memories receive extensive treatment. Other examples include a current loop transmitter, dropout detectors, power management circuits, and clocks. - Step Down Switching Regulators &mdash AN35PDF, 6.2 Мб, Файл опубликован: 1 авг 1989
Discusses the LT1074, an easily applied step-down regulator IC. Basic concepts and circuits are described along with more sophisticated applications. Six appended sections cover LT1074 circuitry detail, inductor and discrete component selection, current measuring techniques, efficiency considerations and other topics.Выписка из документа - Parasitic Capacitance Effects in Step-Up Transformer Design &mdash AN39PDF, 764 Кб, Файл опубликован: 3 фев 1990
This note explores the causes of the large resonating current spikes on the leading edge of the switch current waveform. These anomalies are exacerbated in very high voltage designs.Выписка из документа - LT1074/LT1076 Design Manual &mdash AN44PDF, 477 Кб, Файл опубликован: 1 сен 1991
This note discusses the use of the LT1074 and LT1076 high efficiency switching regulators. These regulators are specifically designed for ease of use. This application note is intended to eliminate the most common errors that customers make when using switching regulators as well as offering insight into the inner workings of switching designs. There is an entirely new treatment of inductor design based upon simple mathematical formulas that yield direct results. There are extensive tutorial sections devoted to the care and feeding of the Positive Step- Down (Buck) Converter, the Tapped Inductor Buck Converter, the Positive-to-Negative Converter and the Negative Boost Converter. Additionally, many troubleshooting hints are included as well as oscilloscope techniques, soft-start architectures, and micropower shutdown and EMI suppression methods.Выписка из документа - Efficiency and Power Characteristics of Switching Regulator Circuits &mdash AN46PDF, 2.6 Мб, Файл опубликован: 1 ноя 1991
Efficiency varies for different DC/DC converters. This application note compares the efficiency characteristics of some of the more popular types. Step-up, step-down, flyback, negative-to-positive, and positive-to-negative are shown. Appended sections discuss how to select the proper aluminum electrolytic capacitor and explain power switch and output diode loss calculations.
Design Notes
- Achieving Microamp Quiescent Current in Switching Regulators &mdash DN11PDF, 95 Кб, Файл опубликован: 1 июн 1988Выписка из документа
- Telephone Ring-Tone Generation &mdash DN134PDF, 80 Кб, Файл опубликован: 1 авг 1996Выписка из документа
- A Battery Powered Lap Top Computer Power Supply &mdash DN18PDF, 90 Кб, Файл опубликован: 1 дек 1988Выписка из документа
- Floating Input Extends Regulator Capabilities &mdash DN21PDF, 71 Кб, Файл опубликован: 1 апр 1989Выписка из документа
- Inductor Selection for LT 1070 Switching Regulators &mdash DN8PDF, 114 Кб, Файл опубликован: 1 мар 1988Выписка из документа
Серия: LT1070 (5)
- LT1070CT#06PBF LT1070CT#30PBF LT1070CT#PBF LT1070IT#06PBF LT1070IT#PBF
- Power Management > Switching Regulator > SEPIC Regulators
- Power Management > Switching Regulator > Step-Up (Boost) Regulators > Internal Power Switch Boost
LT1070IT06PBF, LT1070IT 06PBF
