Datasheet Linear Technology LTC2379CDE-18#TRPBF — Даташит
Серия | LTC2379-18 |
Модель | LTC2379CDE-18#TRPBF |
18-Bit, 1.6Msps, Low Power SAR ADC with 101.2dB SNR
Datasheet LTC2379-18
PDF, 570 Кб, Язык: анг., Файл закачен: 21 авг 2017, Страниц: 26
Купить LTC2379CDE-18#TRPBF на РадиоЛоцман.Цены — от 2 590 до 3 233 ₽ 8 предложений от 8 поставщиков 18 Bit Analog to Digital Converter 1 Input 1 SAR 16-DFN (4x3) | |||
LTC2379CDE-18#TRPBF Analog Devices | 2 590 ₽ | ||
LTC2379CDE-18#TRPBF Linear Technology | 3 233 ₽ | ||
LTC2379CDE-18 TRPBF Linear Technology | по запросу | ||
LTC2379CDE-18#TRPBF Analog Devices | по запросу |
Корпус | 4x3 DFN-16 |
Код корпуса | DE |
Индекс корпуса | 05-08-1732 |
ADC INL | 0.8 LSB |
ADCs | 1 |
Архитектура | SAR |
Bipolar/Unipolar Input | Bipolar |
Bits | 18 bits |
Количество каналов | 1 |
DNL | 0.2 LSB |
Demo Boards | DC1783A-E,DC1805A-E,DC1858A |
Design Tools | LinearLabTools |
Экспортный контроль | нет |
Основные особенности | Digital Gain Compression |
I/O | Serial SPI |
Input Drive | Fully Differential |
Input Span | В±2.5V to В±5.1V |
Internal Reference | нет |
Рабочий диапазон температур | от 0 до 70 °C |
Power | 18 mW |
SFDR | 122 дБ |
SINAD | 101 дБ |
SNR | 101.2 дБ |
Simultaneous | нет |
Speed | 1600 ksps |
Диапазон напряжения питания | 2.5V |
THD dB | -120 дБ |
- Fidelity Testing for A to D Converters &mdash AN132PDF, 3.8 Мб, Файл опубликован: 1 окт 2011
The ability to faithfully digitize a sine wave is a sensitive test of high resolution A to D converter fidelity. This test requires a sine wave generator with residual distortion products approaching one part-per-million. Additionally, a computer-based A to D output monitor is necessary to read and display converter output spectral components. Performing this testing at reasonable cost and complexity requires construction of its elements and performance verification prior to use.Выписка из документа
Design Notes
- Driving a Low Noise, Low Distortion 18-Bit, 1.6Msps ADC &mdash DN494PDF, 1.1 Мб, Файл опубликован: 1 авг 2011Выписка из документа
Статьи
- Low Power, DC Accurate Drivers for 18-Bit ADCs &mdash LT JournalPDF, 3.4 Мб, Файл опубликован: 9 июл 2013Выписка из документа
Серия: LTC2379-18 (10)
- Data Conversion > Analog-to-Digital Converters (ADC) > Precision ADCs (Fs < 10Msps) > Single Channel ADCs
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) ADCs
LTC2379CDE-18TRPBF, LTC2379CDE-18 TRPBF, LTC2379CDE18#TRPBF, LTC2379CDE 18#TRPBF
