Datasheet Linear Technology LTC2351-14 — Даташит
СерияLTC2351-14
6 Channel, 14-Bit, 1.5Msps Simultaneous Sampling ADC with Shutdown
Datasheet LTC2351-14
PDF, 244 Кб, Язык: анг., Файл закачен: 20 авг 2017, Страниц: 20
LTC2351-14по запросу
Критерии выбора литиевых аккумуляторов и батареек: что необходимо учитывать разработчикам
LTC2351CUH-14#PBFLTC2351CUH-14#TRPBFLTC2351HUH-14#PBFLTC2351HUH-14#TRPBFLTC2351IUH-14#PBFLTC2351IUH-14#TRPBF
N123456
Корпус5x5 QFN-32
Габаритный чертеж корпуса
5x5 QFN-32
5x5 QFN-32
5x5 QFN-32
5x5 QFN-32
5x5 QFN-32
Код корпусаUHUHUHUHUHUH
Индекс корпуса05-08-169305-08-169305-08-169305-08-169305-08-169305-08-1693
Количество выводов323232323232
Parameters / ModelsLTC2351CUH-14#PBFLTC2351CUH-14#TRPBFLTC2351HUH-14#PBFLTC2351HUH-14#TRPBFLTC2351IUH-14#PBFLTC2351IUH-14#TRPBF
ADC INL, LSB111111
ADCs111111
АрхитектураSARSARSARSARSARSAR
Bipolar/Unipolar InputUnipolar, BipolarUnipolar, BipolarUnipolar, BipolarUnipolar, BipolarUnipolar, BipolarUnipolar, Bipolar
Bits, bits141414141414
Количество каналов666666
DNL, LSB111111
Demo BoardsDC1278ADC1278ADC1278ADC1278ADC1278ADC1278A
Design ToolsLinearLabToolsLinearLabToolsLinearLabToolsLinearLabToolsLinearLabToolsLinearLabTools
Экспортный контрольнетнетнетнетнетнет
Основные особенностиSimultaneous SamplingSimultaneous SamplingSimultaneous SamplingSimultaneous SamplingSimultaneous SamplingSimultaneous Sampling
I/OSerial SPISerial SPISerial SPISerial SPISerial SPISerial SPI
Input DriveDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully DifferentialDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully DifferentialDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully DifferentialDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully DifferentialDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully DifferentialDifferential with wide input common mode, Single-Ended, Pseudo-Differential, Fully Differential
Input Span0 to 2.5V, В±1.25V0 to 2.5V, В±1.25V0 to 2.5V, В±1.25V0 to 2.5V, В±1.25V0 to 2.5V, В±1.25V0 to 2.5V, В±1.25V
Internal Referenceдададададада
Latency111111
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от -40 до 125от -40 до 125от -40 до 85от -40 до 85
Power, mW16.516.516.516.516.516.5
SFDR, дБ909090909090
SINAD, дБ757575757575
SNR, дБ757575757575
Simultaneousдададададада
Speed, ksps150015001500150015001500
Диапазон напряжения питания3V3V3V3V3V3V
THD dB, дБ-90-90-90-90-90-90
RoHSСовместимСовместимСовместимСовместимСовместимСовместим
Design Notes
  • 6-Channel SAR ADCs for Industrial Monitoring and Portable &mdash DN426
    PDF, 112 Кб, Файл опубликован: 14 сен 2007
Статьи
  • SAR ADCs Feature Speed, Low Power, Small Package Size and True Simultaneous Sampling &mdash LT Journal
    PDF, 197 Кб, Файл опубликован: 14 июн 2007
  • Data Conversion > Analog-to-Digital Converters (ADC) > Precision ADCs (Fs < 10Msps) > Multi Channel ADCs | Simultaneous Sampling ADCs
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) ADCs
На английском языке: Datasheet Linear Technology LTC2351-14
