Datasheet Linear Technology LTC2274 — Даташит
Серия | LTC2274 |
16-Bit, 105Msps Serial Output ADC (JESD204)
Datasheet LTC2274
PDF, 924 Кб, Язык: анг., Файл закачен: 20 авг 2017, Страниц: 40
Купить LTC2274 на РадиоЛоцман.Цены — от 5 870 до 30 018 ₽ 18 предложений от 16 поставщиков 16 Bit Analog to Digital Converter 1 Input 1 Pipelined 40-QFN (6x6) | |||
LTC2274CUJ#TRPBF Analog Devices | 5 870 ₽ | ||
LTC2274CUJ#TRPBF Linear Technology | 7 336 ₽ | ||
LTC2274IUJ Linear Technology | по запросу | ||
LTC2274IUJ-TR | по запросу |
LTC2274CUJ#PBF | LTC2274CUJ#TRPBF | LTC2274IUJ#PBF | LTC2274IUJ#TRPBF | |
N | 1 | 2 | 3 | 4 |
Корпус | 6x6 QFN-40 Габаритный чертеж корпуса | 6x6 QFN-40 Габаритный чертеж корпуса | 6x6 QFN-40 Габаритный чертеж корпуса | 6x6 QFN-40 Габаритный чертеж корпуса |
Код корпуса | UJ | UJ | UJ | UJ |
Индекс корпуса | 05-08-1728 | 05-08-1728 | 05-08-1728 | 05-08-1728 |
Количество выводов | 40 | 40 | 40 | 40 |
Parameters / Models | LTC2274CUJ#PBF | LTC2274CUJ#TRPBF | LTC2274IUJ#PBF | LTC2274IUJ#TRPBF |
ADC INL, LSB | 1.2 | 1.2 | 1.2 | 1.2 |
ADCs | 1 | 1 | 1 | 1 |
Архитектура | Pipeline | Pipeline | Pipeline | Pipeline |
Bipolar/Unipolar Input | Bipolar | Bipolar | Bipolar | Bipolar |
Bits, bits | 16 | 16 | 16 | 16 |
Количество каналов | 1 | 1 | 1 | 1 |
DNL, LSB | 0.3 | 0.3 | 0.3 | 0.3 |
Demo Boards | DC1151A-C,DC1151A-D | DC1151A-C,DC1151A-D | DC1151A-C,DC1151A-D | DC1151A-C,DC1151A-D |
Экспортный контроль | да | да | да | да |
Основные особенности | 2.1Gbps JESD204, High IF Sampling, PGA, Internal Dither, Clock Duty Cycle Stabilizer | 2.1Gbps JESD204, High IF Sampling, PGA, Internal Dither, Clock Duty Cycle Stabilizer | 2.1Gbps JESD204, High IF Sampling, PGA, Internal Dither, Clock Duty Cycle Stabilizer | 2.1Gbps JESD204, High IF Sampling, PGA, Internal Dither, Clock Duty Cycle Stabilizer |
I/O | Serial JESD204 | Serial JESD204 | Serial JESD204 | Serial JESD204 |
Input Drive | Differential | Differential | Differential | Differential |
Input Span | 2.25Vpp or 1.5Vpp | 2.25Vpp or 1.5Vpp | 2.25Vpp or 1.5Vpp | 2.25Vpp or 1.5Vpp |
Internal Reference | да | да | да | да |
Latency | 9 | 9 | 9 | 9 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от -40 до 85 | от -40 до 85 |
Power, mW | 1300 | 1300 | 1300 | 1300 |
SFDR, дБ | 100 | 100 | 100 | 100 |
SINAD, дБ | 77.6 | 77.6 | 77.6 | 77.6 |
SNR, дБ | 77.6 | 77.6 | 77.6 | 77.6 |
Simultaneous | нет | нет | нет | нет |
Speed, ksps | 105000 | 105000 | 105000 | 105000 |
Диапазон напряжения питания | 3.3V | 3.3V | 3.3V | 3.3V |
RoHS | Совместим | Совместим | Совместим | Совместим |
Design Notes
- Maximize the Performance of 16-Bit, 105Msps ADC with Careful IF SIgnal Chain Design &mdash DN468PDF, 93 Кб, Файл опубликован: 30 май 2009Выписка из документа
Статьи
- Maximize the Performance of 16-Bit, 105Msps ADC with Careful IF Signal Chain Design &mdash LT JournalPDF, 273 Кб, Файл опубликован: 1 дек 2009Выписка из документа
- Serial Interface for High Speed Data Converters Simplifies Layout over Traditional Parallel Devices &mdash LT JournalPDF, 417 Кб, Файл опубликован: 23 сен 2008Выписка из документа
Серия: LTC2274 (4)
- Data Conversion > Analog-to-Digital Converters (ADC) > High Speed ADCs (Fs >=10Msps)
