Datasheet Linear Technology LTC1098CS8#PBF — Даташит
Серия | LTC1098 |
Модель | LTC1098CS8#PBF |
Micropower Sampling 8-Bit Serial I/O A/D Converters
Datasheet LTC1096, LTC1096L, LTC1098, LTC1098L
PDF, 292 Кб, Язык: анг., Файл закачен: 16 авг 2017, Страниц: 32
Купить LTC1098CS8#PBF на РадиоЛоцман.Цены — от 206 до 1 573 ₽ 26 предложений от 18 поставщиков Analog to Digital Converter Single SAR 33K Single Pole 8Bit Serial 8Pin SOIC N | |||
LTC1098CS8#PBF Analog Devices | 206 ₽ | ||
LTC1098CS8#TRPBF Linear Technology | 235 ₽ | ||
LTC1098CS8#TRPBF Linear Technology | 239 ₽ | ||
LTC1098CS8#TRPBF Analog Devices | по запросу |
Корпус | SO-8 |
Код корпуса | S8 |
Индекс корпуса | 05-08-1610 (S8) |
ADC INL | 0.5 LSB |
ADCs | 1 |
Архитектура | SAR |
Bipolar/Unipolar Input | Unipolar |
Bits | 8 bits |
Количество каналов | 2 |
DNL | 1 LSB |
Экспортный контроль | нет |
I/O | Serial SPI |
Input Drive | Pseudo-Differential, Single-Ended |
Input Span | 0V to 5V |
Internal Reference | нет |
Рабочий диапазон температур | от 0 до 70 °C |
Power | 0.78 mW |
SINAD | 43.3 дБ |
Simultaneous | нет |
Speed | 33 ksps |
Диапазон напряжения питания | 5V |
LTC1096 LTC1096 LTC1096A LTC1096L LTC1098A LTC1098L
- Linear Technology Magazine Circuit Collection, Volume 1 &mdash AN52PDF, 190 Кб, Файл опубликован: 1 янв 1993
This application note consolidates the circuits from the first few years of Linear Technology magazine into one publication. Presented in the note are a variety of circuits ranging from a 50W high efficiency (>90%) switching regulator to steep roll-off filter circuits with low distortion to 12-bit differential temperature measurement systems.Выписка из документа - Data Acquisition Circuit Collection &mdash AN62PDF, 349 Кб, Файл опубликован: 1 окт 1994
This application note presents a wide variety of data acquisition circuits. The detailed circuit schematics cover 8-, 10-, and 12- bit ADC and DAC applications, serial and parallel digital interfaces, battery monitoring, temperature sensing, isolated interfaces, and connections to various popular microprocessors and microcontrollers. An appendix covers suggested voltage references.Выписка из документа
Design Notes
- Micropower 12-Bit ADCs Shrink Board Space &mdash DN116PDF, 74 Кб, Файл опубликован: 1 окт 1995Выписка из документа
- The LTC1096 and LTC1098: Micropower, SO-8, 8-Bit ADCs Sample at 1kHz on 3ОјA of Supply Current &mdash DN60PDF, 76 Кб, Файл опубликован: 1 май 1992Выписка из документа
Серия: LTC1098 (6)
- LTC1098CN8#PBF LTC1098CS8#PBF LTC1098CS8#TRPBF LTC1098IN8#PBF LTC1098IS8#PBF LTC1098IS8#TRPBF
- Data Conversion > Analog-to-Digital Converters (ADC) > Precision ADCs (Fs < 10Msps) > Multi Channel ADCs
LTC1098CS8PBF, LTC1098CS8 PBF
