Datasheet Microchip MCP6293-E/MS — Даташит
Производитель | Microchip |
Серия | MCP629 |
Модель | MCP6293-E/MS |
The MCP62x family of operational amplifiers feature low offset.
Datasheet MCP621S, MCP621S, MCP622, MCP623, MCP624, MCP625, MCP629
PDF, 2.2 Мб, Язык: анг., Файл опубликован: 7 авг 2014, Страниц: 62
Datasheet MCP6291, MCP6291R, MCP6292, MCP6293, MCP6294, MCP6295
PDF, 678 Кб, Язык: анг., Файл опубликован: 13 ноя 2007, Страниц: 36
The Microchip Technology MCP6291/1R/2/3/4/5 family of operational amplifiers (op amps) provide wide bandwidth for the current
Купить MCP6293-E/MS на РадиоЛоцман.Цены — от 38 до 192 ₽ 19 предложений от 13 поставщиков General Purpose Amplifier 1 Circuit Rail-to-Rail 8-MSOP | |||
MCP6293-E/MS Microchip | 38 ₽ | ||
MCP6293-E/MS Microchip | 58 ₽ | ||
MCP6293-E/MS Microchip | от 67 ₽ | ||
MCP6293-E/MS Microchip | 192 ₽ |
At power-up, these op amps are self-calibrated using mCal. Some package options also provide a calibration/chip select pin that supports a low power mode of operation, with offset calibration at the time normal operation is re-started. These amplifiers are optimized for high speed, low noise and distortion, single-supply operation with rail-to-rail output and an input that includes the negative rail. AEC-Q100 Grade 1 qualification is available for this device
Корпус | MSOP |
Количество каналов | 4 |
Aol | 117 дБ |
Automotive Recommended | Yes |
CMRR Min | 65 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 20000 kHz |
Ib | 5 pA |
Input Voltage Noise Density | 13 nV/rt(Hz) |
Iq Max | 3600 µA |
Iq Typical | 2500 µA |
Isc | 70 мА |
Lead Count | 8 |
Operating Voltage Range | 2.5 - 5.5 В |
PM | 60 deg |
PSRR Min | 61 дБ |
Package Width | 3x3mm |
Rail-To-Rail | Out |
Скорость нарастания | 10 V/µS |
Unity Gain Stable | Yes |
Vos Max | 200 µV |
ΔVos/ΔTa | 2 µV/°C |
MCP621 MCP621S MCP622 MCP623 MCP624 MCP625
Серия: MCP629 (40)
- MCP629-E/ML MCP6291-E/MS MCP6291-E/P MCP6291-E/SN MCP6291RT-E/OT MCP6291T-E/MS MCP6291T-E/OT MCP6291T-E/OTVAO MCP6291T-E/SN MCP6292-E/MS MCP6292-E/P MCP6292-E/SN MCP6292-E/SNVAO MCP6292-H/MS MCP6292T-E/MS MCP6292T-E/MSVAO MCP6292T-E/SN MCP6292T-E/SNVAO MCP6292T-H/MS MCP6293-E/MS MCP6293-E/P MCP6293-E/SN MCP6293T-E/CH MCP6293T-E/MS MCP6293T-E/SN MCP6294-E/P MCP6294-E/SL MCP6294-E/SLVAO MCP6294-E/ST MCP6294-E/STVAO MCP6294T-E/SL MCP6294T-E/SLVAO MCP6294T-E/ST MCP6294T-E/STVAO MCP6295-E/MS MCP6295-E/P MCP6295-E/SN MCP6295T-E/MS MCP6295T-E/SN MCP629T-E/ML
- Amplifiers and Linear > Operational Amplifiers > Precision
MCP6293E/MS, MCP6293 E/MS
