Datasheet Microchip MCP6494-E/ST — Даташит
Производитель | Microchip |
Серия | MCP6494 |
Модель | MCP6494-E/ST |
The Microchip’s MCP6491/2/4 family of operational amplifiers (op amps) has low input bias current (150 pA, typical at 125°C) and rail-to-rail input and output operation.
The Microchip’s MCP6491 operational amplifiers (op amps) has low input bias current (150 pA, typical at 125°C) and rail-to-rail input and output operation
Купить MCP6494-E/ST на РадиоЛоцман.Цены — от 58 до 396 ₽ 24 предложений от 14 поставщиков MICROCHIP MCP6494-E/ST Operational Amplifier, Quad, 4 Amplifier, 7.5MHz, 6V/µs, 2.4V to 5.5V, TSSOP, 14Pins | |||
MCP6494-E/ST Microchip | 58 ₽ | ||
MCP6494-E/ST Microchip | 98 ₽ | ||
MCP6494-E/ST Microchip | от 396 ₽ | ||
MCP6494-E/ST Microchip | по запросу |
This family is unity gain stable and has a gain bandwidth product of 7.5 MHz (typical). These devices operate with a single-supply voltage as low as 2.0V, while only drawing 530 µA/amplifier (typical) of quiescent current. These features make the family of op amps well suited for photodiode amplifier, pH electrode amplifier, low leakage amplifier, and battery powered signal conditioning applications, etc. All devices are designed using an advanced CMOS process and fully specified in extended temperature range from -40°C to +125°C.
Корпус | TSSOP |
Количество каналов | 4 |
Aol | 115 дБ |
Automotive Recommended | Yes |
CMRR Min | 88 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 7500 kHz |
Ib | 1 pA |
Input Voltage Noise Density | 14 nV/rt(Hz) |
Iq Max | 800 µA |
Iq Typical | 530 µA |
Isc | 40 мА |
Lead Count | 14 |
Operating Voltage Range | 2.4 - 5.5 В |
PM | 57 deg |
PSRR Min | 90 дБ |
Package Width | 4.4mm |
Rail-To-Rail | In/Out |
Скорость нарастания | 6 V/µS |
Unity Gain Stable | Yes |
Vos Max | 1500 µV |
ΔVos/ΔTa | 2.5 µV/°C |
- MCP6494-E/SL MCP6494-E/ST MCP6494T-E/SL MCP6494T-E/ST MCP6494T-E/STVAO
- Amplifiers and Linear > Operational Amplifiers > General Purpose
MCP6494E/ST, MCP6494 E/ST
