Datasheet Microchip MCP6024T-E/STVAO — Даташит
Производитель | Microchip |
Серия | MCP6024 |
Модель | MCP6024T-E/STVAO |
The MCP6024 quad operational amplifier (op amp) has a gain bandwidth product of 10 MHz with a low typical operating current of 1.0 mA and an offset voltage that is less than 0.5 mV.
The MCP6021 operational amplifier (op amp) has a gain bandwidth product of 10 MHz with a low typical operating current of 1.0 mA and an offset voltage that is less than 0.5 mV
MCP601 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230 uA and an offset voltage that is less than 2 mV
Купить MCP6024T-E/STVAO на РадиоЛоцман.Цены — от 187 до 198 ₽ 7 предложений от 4 поставщиков IC OPAMP GP 10MHZ RRO 14TSSOP | |||
MCP6024T-E/STVAO Microchip | 187 ₽ | ||
MCP6024T-E/STVAO Microchip | 190 ₽ | ||
MCP6024T-E/STVAO Microchip | от 198 ₽ | ||
MCP6024T-E/STVAO Microchip | по запросу |
The MCP6024 uses Microchip's advanced CMOS technology, which provides low bias current, high-speed operation, high open-loop gain and rail-to-rail output swing. The MCP6024 operates with a single supply voltage that can be as low as 2.5 V, while drawing less than 1.35 mA of quiescent current per amplifier. The MCP6024 is available in standard 14-lead PDIP, SOIC and TSSOP packages. This amplifier is ideal for battery and loop-powered applications as well as industrial process control, low-power battery-operated devices, portable equipment, data acquisition equipment, test equipment and low-end audio applications.AEC-Q100 Grade 1 qualification is available for this device
Корпус | TSSOP |
Количество каналов | 4 |
Aol | 110 дБ |
Automotive Recommended | Yes |
CMRR Min | 74 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 10000 kHz |
Ib | 1 pA |
Input Voltage Noise Density | 8.7 nV/rt(Hz) |
Iq Max | 1350 µA |
Iq Typical | 1000 µA |
Isc | 30 мА |
Lead Count | 14 |
Operating Voltage Range | 2.5 - 5.5 В |
PM | 65 deg |
PSRR Min | 74 дБ |
Package Width | 4.4mm |
Rail-To-Rail | In/Out |
Скорость нарастания | 7 V/µS |
Unity Gain Stable | Yes |
Vos Max | 250 µV |
ΔVos/ΔTa | 3.5 µV/°C |
MCP6021 MCP6021R MCP6022 MCP6023
- Amplifiers and Linear > Operational Amplifiers > Precision
MCP6024TE/STVAO, MCP6024T E/STVAO
