Datasheet Linear Technology LTC6240HV — Даташит
Серия | LTC6240HV |
Single 18MHz, Low Noise, Rail-to-Rail Output, CMOS Op Amp
Datasheet LTC6240, LTC6241, LTC6242
PDF, 435 Кб, Язык: анг., Файл закачен: 31 июл 2016, Страниц: 32
Купить LTC6240HVCS5#PBF на РадиоЛоцман.Цены — от 120 до 672 ₽ 29 предложений от 19 поставщиков Single/Dual/Quad 18MHz, Low Noise, Rail-to-Rail Output, CMOS Op Amps | |||
LTC6240HVCS5#TRMPBF Analog Devices | 120 ₽ | ||
LTC6240HVCS5 LTC1799IS5 LTC1728ES5-3.3 LTC2054IS5 LTC3406BES5-1.8 LTC1694IS5 IC | 140 ₽ | ||
LTC6240HVCS5#TRPBF Linear Technology | 186 ₽ | ||
LTC6240HVCS5#TRMPBF Linear Technology | по запросу |
Parameters / Models | LTC6240HVCS5#PBF | LTC6240HVCS5#TRMPBF | LTC6240HVCS5#TRPBF | LTC6240HVCS8#PBF | LTC6240HVCS8#TRPBF | LTC6240HVHS5#PBF | LTC6240HVHS5#TRMPBF | LTC6240HVHS5#TRPBF | LTC6240HVHS8#PBF | LTC6240HVHS8#TRPBF | LTC6240HVIS5#PBF | LTC6240HVIS5#TRMPBF | LTC6240HVIS5#TRPBF | LTC6240HVIS8#PBF | LTC6240HVIS8#TRPBF |
Av Min Stable, V/V | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Avol, дБ | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 | 64 |
CMRR, дБ | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 | 105 |
Cdiff, пФ | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Cload, пФ | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 |
Demo Boards | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Enoise 1/f Corner, Hz | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 |
Enoise Density, нВ/rtГц | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
GBW, МГц | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
Ibias, нА | 0.0002 | 0.0002 | 0.0002 | 0.0002 | 0.0002 | 0.0002 | 0.0002 | 0.0002 | 0.0002 | 0.0002 | 0.0002 | 0.0002 | 0.0002 | 0.0002 | 0.0002 |
Inoise, пА/rtГц | 0.00056 | 0.00056 | 0.00056 | 0.00056 | 0.00056 | 0.00056 | 0.00056 | 0.00056 | 0.00056 | 0.00056 | 0.00056 | 0.00056 | 0.00056 | 0.00056 | 0.00056 |
Inoise 1/f Corner, Hz | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 |
Ios, мкА | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 | 0.0000002 |
Iout, мА | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 |
Isupply, мА | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
LF Enoise, µVPP | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Over-the-Top | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
PSRR, дБ | 104 | 104 | 104 | 104 | 104 | 104 | 104 | 104 | 104 | 104 | 104 | 104 | 104 | 104 | 104 |
Rail-to-Rail | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output |
Rail-to-Rail In | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Rail-to-Rail Out | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
SR, В/мс | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Shutdown | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Single Supply | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Ts (0.1%), нс | 1100 | 1100 | 1100 | 1100 | 1100 | 1100 | 1100 | 1100 | 1100 | 1100 | 1100 | 1100 | 1100 | 1100 | 1100 |
Тип | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB | CMOS, VFB |
VinCM High (from V+), В | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 |
Voh (from V+), В | .011 | .011 | .011 | .011 | .011 | .011 | .011 | .011 | .011 | .011 | .011 | .011 | .011 | .011 | .011 |
Vol (from V-), В | .007 | .007 | .007 | .007 | .007 | .007 | .007 | .007 | .007 | .007 | .007 | .007 | .007 | .007 | .007 |
Vos, мВ | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 |
Vos TC, мВ/C | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 |
Vs макс., В | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 |
Vs мин., В | 2.8 | 2.8 | 2.8 | 2.8 | 2.8 | 2.8 | 2.8 | 2.8 | 2.8 | 2.8 | 2.8 | 2.8 | 2.8 | 2.8 | 2.8 |
LTC6240HVCS5#PBF | LTC6240HVCS5#TRMPBF | LTC6240HVCS5#TRPBF | LTC6240HVCS8#PBF | LTC6240HVCS8#TRPBF | LTC6240HVHS5#PBF | LTC6240HVHS5#TRMPBF | LTC6240HVHS5#TRPBF | LTC6240HVHS8#PBF | LTC6240HVHS8#TRPBF | LTC6240HVIS5#PBF | LTC6240HVIS5#TRMPBF | LTC6240HVIS5#TRPBF | LTC6240HVIS8#PBF | LTC6240HVIS8#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
LTC6240 LTC6240 LTC6241 LTC6241 LTC6241HV LTC6242 LTC6242 LTC6242HV
Статьи
- Fast CMOS Op Amp Challenges Bipolar Amps on All Key Specs &mdash LT JournalPDF, 264 Кб, Файл опубликован: 28 мар 2006Выписка из документа
Серия: LTC6240HV (15)
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | Low Noise Amplifiers ( | Low Bias Current Amplifiers (Ib < 100pA) | Rail-to-Rail Amplifiers
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
