Datasheet Linear Technology LT6013 — Даташит
Серия | LT6013 |
Single 145µA, 9.5nV/rtHz, AV >=5, Rail-to-Rail Output Precision Op Amps
Datasheet LT6013, LT6014
PDF, 346 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 16
Single/Dual 145µA, 9.5nV/√Hz, AV ≥5, Rail-to-Rail Output Precision Op Amps
Купить LT6013 на РадиоЛоцман.Цены — от 91 до 713 ₽ 33 предложений от 23 поставщиков Single/Dual 145UA, 9.5nV/ SIGMAHz, AV >5, Rail-to-Rail Output Precision Op Amps | |||
LT6013CS8 Analog Devices | 91 ₽ | ||
LT6013CS8 Linear Technology | 110 ₽ | ||
LT6013 | по запросу | ||
LT6013ACDD Linear Technology | по запросу |
Parameters / Models | LT6013ACDD#PBF | LT6013ACDD#TRPBF | LT6013ACS8#PBF | LT6013ACS8#TRPBF | LT6013AIDD#PBF | LT6013AIDD#TRPBF | LT6013AIS8#PBF | LT6013AIS8#TRPBF | LT6013CDD#PBF | LT6013CDD#TRPBF | LT6013CS8#PBF | LT6013CS8#TRPBF | LT6013IDD#PBF | LT6013IDD#TRPBF | LT6013IS8#PBF | LT6013IS8#TRPBF |
Av Min Stable, V/V | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 |
Avol, дБ | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 |
CMRR, дБ | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Cload, пФ | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 |
Demo Boards | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Enoise 1/f Corner, Hz | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Enoise Density, нВ/rtГц | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 | 9.5 |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
GBW, МГц | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 |
Ibias, нА | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 |
Inoise, пА/rtГц | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 | 0.15 |
Inoise 1/f Corner, Hz | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 |
Ios, мкА | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 | 0.0001 |
Iout, мА | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 |
Isupply, мА | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 | 0.145 |
LF Enoise, µVPP | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Over-the-Top | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
PSRR, дБ | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 |
Rail-to-Rail | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output |
Rail-to-Rail In | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Rail-to-Rail Out | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
SR, В/мс | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 |
Shutdown | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Single Supply | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ts (0.1%), нс | 20000 | 20000 | 20000 | 20000 | 20000 | 20000 | 20000 | 20000 | 20000 | 20000 | 20000 | 20000 | 20000 | 20000 | 20000 | 20000 |
Тип | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB |
VinCM High (from V+), В | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
VinCM Low (from V-), В | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 |
Voh (from V+), В | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 |
Vol (from V-), В | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 |
Vos, мВ | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 |
Vos TC, мВ/C | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 |
Vs макс., В | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 |
Vs мин., В | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
LT6013ACDD#PBF | LT6013ACDD#TRPBF | LT6013ACS8#PBF | LT6013ACS8#TRPBF | LT6013AIDD#PBF | LT6013AIDD#TRPBF | LT6013AIS8#PBF | LT6013AIS8#TRPBF | LT6013CDD#PBF | LT6013CDD#TRPBF | LT6013CS8#PBF | LT6013CS8#TRPBF | LT6013IDD#PBF | LT6013IDD#TRPBF | LT6013IS8#PBF | LT6013IS8#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LT6013 (16)
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | Low Noise Amplifiers ( | Low Power Amplifiers (Is < 1mA/amp) | Low Bias Current Amplifiers (Ib < 100pA) | High Voltage Amplifiers (>12V) | Rail-to-Rail Amplifiers
