Datasheet Linear Technology LT1999-20 — Даташит
Серия | LT1999-20 |
High Voltage, Bidirectional Current Sense Amplifier
LT1999-10/LT1999-20/ LT1999-50 - High Voltage, Bidirectional Current Sense Amplifier
PDF, 1.0 Мб, Версия: D, Файл закачен: 6 авг 2017
Купить LT1999 на РадиоЛоцман.Цены — от 325 до 817 ₽ 12 предложений от 12 поставщиков High Voltage, Bidirectional Current Sense Amplifier Low Power Shutdown | |||
LT1999IS8-50 Analog Devices | 325 ₽ | ||
LT1999CS8-50 Linear Technology | 457 ₽ | ||
LT1999HMS8-10 Linear Technology | по запросу | ||
LT1999MPMS8-20 | по запросу |
Parameters / Models | LT1999CMS8-20#PBF | LT1999CMS8-20#TRPBF | LT1999CMS8-20F#PBF | LT1999CMS8-20F#TRPBF | LT1999CS8-20#PBF | LT1999CS8-20#TRPBF | LT1999HMS8-20#PBF | LT1999HMS8-20#TRPBF | LT1999HMS8-20F#PBF | LT1999HMS8-20F#TRPBF | LT1999HS8-20#PBF | LT1999HS8-20#TRPBF | LT1999IMS8-20#PBF | LT1999IMS8-20#TRPBF | LT1999IMS8-20F#PBF | LT1999IMS8-20F#TRPBF | LT1999IS8-20#PBF | LT1999IS8-20#TRPBF | LT1999MPMS8-20#PBF | LT1999MPMS8-20#TRPBF | LT1999MPMS8-20F#PBF | LT1999MPMS8-20F#TRPBF | LT1999MPS8-20#PBF | LT1999MPS8-20#TRPBF |
3dB Error Bandwidth, kHz | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 |
Bidirectional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional | Bi-directional |
CM Range | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V | -5V to 80V |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Current Sense Topology | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side | High Side, Low Side |
Demo Boards | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C | DC1698A-A,DC1698A-B,DC1698A-C |
Design Tools | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground | Bidirectional Current Sense, Input Common Mode Extends Below Ground |
GBW, МГц | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Gain, V/V | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Точность коэффициента усиления, % | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 |
Ibias, мкА | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 | 137 |
Input Step Response | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us | 2.5us |
Iout, мА | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 | 31 |
Isupply, мА | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 | 1.55 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
PSRR, дБ | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 | 77 |
Rail-to-Rail In | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Rail-to-Rail Out | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ts (0.1%), нс | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
Тип | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA | CSA |
Vos, мВ | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
Vos TC, мВ/C | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 |
Vs макс., В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
Vs мин., В | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
Vsense Max, мВ | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 |
LT1999CMS8-20#PBF | LT1999CMS8-20#TRPBF | LT1999CMS8-20F#PBF | LT1999CMS8-20F#TRPBF | LT1999CS8-20#PBF | LT1999CS8-20#TRPBF | LT1999HMS8-20#PBF | LT1999HMS8-20#TRPBF | LT1999HMS8-20F#PBF | LT1999HMS8-20F#TRPBF | LT1999HS8-20#PBF | LT1999HS8-20#TRPBF | LT1999IMS8-20#PBF | LT1999IMS8-20#TRPBF | LT1999IMS8-20F#PBF | LT1999IMS8-20F#TRPBF | LT1999IS8-20#PBF | LT1999IS8-20#TRPBF | LT1999MPMS8-20#PBF | LT1999MPMS8-20#TRPBF | LT1999MPMS8-20F#PBF | LT1999MPMS8-20F#TRPBF | LT1999MPS8-20#PBF | LT1999MPS8-20#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LT1999-20 (24)
- LT1999CMS8-20#PBF LT1999CMS8-20#TRPBF LT1999CMS8-20F#PBF LT1999CMS8-20F#TRPBF LT1999CS8-20#PBF LT1999CS8-20#TRPBF LT1999HMS8-20#PBF LT1999HMS8-20#TRPBF LT1999HMS8-20F#PBF LT1999HMS8-20F#TRPBF LT1999HS8-20#PBF LT1999HS8-20#TRPBF LT1999IMS8-20#PBF LT1999IMS8-20#TRPBF LT1999IMS8-20F#PBF LT1999IMS8-20F#TRPBF LT1999IS8-20#PBF LT1999IS8-20#TRPBF LT1999MPMS8-20#PBF LT1999MPMS8-20#TRPBF LT1999MPMS8-20F#PBF LT1999MPMS8-20F#TRPBF LT1999MPS8-20#PBF LT1999MPS8-20#TRPBF
- Signal Conditioning > Amplifiers > Current Sense Amplifiers
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
