Datasheet Microchip ATTINY20-CCU — Даташит
Производитель | Microchip |
Серия | ATtiny20 |
Модель | ATTINY20-CCU |
The high-performance, low-power Microchip 8-bit AVR RISC-based microcontroller combines 2KB ISP flash memory, 128B SRAM, twelve general purpose I/O lines, 16 general purpose working registers, an 8-bit timer/counter with two PWM channels, a 16-bit timer/counter with two PWM channels, internal and external interrupts, an 8-channel 10-bit A/D converter, programmable watchdog timer with internal oscillator, a slave two-wire interface, a master/slave serial peripheral interface, an internal calibrated oscillator, and four software selectable power saving modes
Купить ATTINY20-CCU на РадиоЛоцман.Цены — от 45 до 258 ₽ 18 предложений от 13 поставщиков MCU 8-Bit ATtiny AVR RISC 2KB Flash 2.5V/3.3V/5V 15-Pin UFBGA | |||
ATTINY20-CCU Microchip | 45 ₽ | ||
ATTINY20-CCU Atmel | 79 ₽ | ||
ATTINY20-CCU Atmel | 121 ₽ | ||
ATTINY20-CCU Atmel | по запросу |
Корпус | UFBGA |
ADC Input | 8 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | Yes |
Lead Count | 15 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max 8-Bit Digital Timers | 1 |
Max CPU Speed | 12 МГц |
Max PWM outputs | 3 including complementary |
Количество компараторов | 1 |
Package Width | 3x3x0.6mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 14 |
Размер памяти программ | 2 KB |
SPI | 1 |
SRAM | 128 Bytes |
Temp Range Max | 85 |
Temp Range Min | -40 |
Zero Cross detect | No |
Серия: ATtiny20 (10)
- Microcontrollers > 8-bit Microcontrollers
ATTINY20CCU, ATTINY20 CCU
