Datasheet Texas Instruments THS4552IPWR — Даташит
Серия | THS4552 |
Модель | THS4552IPWR |
Dual Channel, Low-Noise, Precision, 150-MHz, Fully Differential Amplifier 16-TSSOP -40 to 125
THS4552 Dual-Channel, Low-Noise, Precision, 150-MHz, Fully Differential Amplifier datasheet
PDF, 2.9 Мб, Версия: A, Файл опубликован: 19 июл 2017
Купить THS4552IPWR на РадиоЛоцман.Цены — от 510 до 19 572 ₽ 11 предложений от 8 поставщиков Dual Channel, Low-Noise, Precision, 150MHz, Fully Differential Amplifier 16-TSSOP -40℃ to 125℃ | |||
THS4552IPWR Texas Instruments | 510 ₽ | ||
THS4552IPWR Texas Instruments | 537 ₽ | ||
THS4552IPWR | 19 572 ₽ | ||
THS4552IPWR Texas Instruments | по запросу |
Pin | 16 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | THS4552 |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
2nd Harmonic | 128 dBc |
3rd Harmonic | 139 dBc |
@ MHz | 0.1 |
Acl, min spec gain | 1 V/V |
Additional Features | Shutdown |
Архитектура | Bipolar,Fully Differential,Voltage FB |
BW @ Acl | 150 МГц |
CMRR(Min) | 93 дБ |
CMRR(Typ) | 110 дБ |
Input Bias Current(Max) | 1500000 pA |
Iq per channel(Max) | 1.44 мА |
Iq per channel(Typ) | 1.37 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 0.45 uV/C |
Output Current(Typ) | 65 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 220 V/us |
Total Supply Voltage(Max) | 5.4 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 3.3 нВ/rtГц |
Vn at Flatband(Typ) | 3.3 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.265 мВ |
- Evaluation Modules & Boards: THS4552RTWEVM
THS4552RTW Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: THS4552PWEVM
THS4552PW Evaluation Module
- Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS4552 (4)
- THS4552IPWR THS4552IPWT THS4552IRTWR THS4552IRTWT
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
