Datasheet Texas Instruments SN74LVC2G06-Q1 — Даташит
Серия | SN74LVC2G06-Q1 |
Automotive Catalog Dual Inverter Buffer/Driver with Open-Drain Output
Dual Inverter Buffer/Driver With Open-Drain Outputs datasheet
PDF, 742 Кб, Версия: A, Файл опубликован: 10 апр 2008
DUAL INVERTER BUFFER/DRIVER WITH OPEN DRAIN OUTPUTS | |||
SN74LVC2G06-Q1 Texas Instruments | по запросу |
SN74LVC2G06QDCKRQ1 | |
Статус продукта | В производстве |
N | 1 |
Pin | 6 |
Package Type | DCK |
Industry STD Term | SOT-SC70 |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | CTO |
Width (мм) | 1.25 |
Length (мм) | 2 |
Thickness (мм) | .9 |
Pitch (мм) | .65 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
Parameters / Models | SN74LVC2G06QDCKRQ1 |
3-State Output | No |
Bits | 2 |
F @ Nom Voltage(Max), Mhz | 150 |
Gate Type | OPEN DRAIN INVERTER BUFFER |
ICC @ Nom Voltage(Max), мА | 0.01 |
Logic | Inverting |
Рабочий диапазон температур, C | от -40 до 125 |
Output Drive (IOL/IOH)(Max), мА | 32/-32 |
Package Group | SC70 |
Package Size: mm2:W x L, PKG | 6SC70: 4 mm2: 2.1 x 2(SC70) |
Rating | Automotive |
Schmitt Trigger | No |
Special Features | Ioff,down translation to Vcc,low power,Open drain |
Sub-Family | Inverting Buffer/Driver |
Technology Family | LVC |
VCC(Max), В | 5.5 |
VCC(Min), В | 1.65 |
Voltage(Nom), В | 1.8,2.5,3.3,5 |
tpd @ Nom Voltage(Max), нс | 7.2,3.9,3.4,2.9 |
Серия: SN74LVC2G06-Q1 (1)
- Semiconductors> Logic> Little Logic
