Datasheet Texas Instruments PTH08T220WAZ — Даташит
Серия | PTH08T220W |
Модель | PTH08T220WAZ |
16-A, 4.5-V to 14-V Input, Non-Isolated, Wide Output Adjust, Power Module w/ TurboTrans 11-Surface Mount Module -40 to 85
16-A, 4.5-V to 14-V Input, Non-Isolated, Wide Output Adjustable Power Module datasheet
PDF, 1.3 Мб, Версия: K, Файл опубликован: 29 июн 2009
Купить PTH08T220WAZ на РадиоЛоцман.Цены — от 1 530 до 6 684 ₽ 22 предложений от 11 поставщиков TEXAS INSTRUMENTS PTH08T220WAZ Non Isolated POL DC-DC Converter, Adjustable, POLA, Surface Mount DIP, 88W, 690mV, 5.5V, 16A | |||
PTH08T220WAZ Texas Instruments | 1 530 ₽ | ||
PTH08T220WAZ Texas Instruments | 1 748 ₽ | ||
PTH08T220WAZ Texas Instruments | от 6 684 ₽ | ||
PTH08T220WAZ Texas Instruments | по запросу |
Pin | 11 |
Package Type | BAT |
Industry STD Term | Surface Mount Module |
JEDEC Code | R-PDSS-B |
Package QTY | 42 |
Carrier | TIW TRAY |
Width (мм) | 18.93 |
Length (мм) | 22.1 |
Thickness (мм) | 8.25 |
Pitch (мм) | 2.54 |
Max Height (мм) | 8.5 |
Mechanical Data | Скачать |
Iout(Max) | 16 A |
Package Size: mm2:W x L | 11Surface Mount Module: 461 mm2: 19.94 x 23.11(Surface Mount Module),11Surface Mount Module: 461 mm2: 23.11 x 19.94(Surface Mount Module),11Through-Hole Module: 418 mm2: 18.93 x 22.1(Through-Hole Module) PKG |
Package Type | Open-Frame |
Regulated Outputs | 1 |
Special Features | TurboTrans |
Vin(Max) | 14 В |
Vin(Min) | 4.5 В |
Vout(Max) | 5.5 В |
Vout(Min) | 0.7 В |
RoHS | Не совместим |
- Power management for processor core voltage requirementsPDF, 186 Кб, Файл опубликован: 14 дек 2006
- Power Two Xilinx(TM) LX240 Virtex-6(TM) DevicesPDF, 63 Кб, Файл опубликован: 20 апр 2010
This reference design is intended to help designers wishing to use two of the new Virtex-6™ LX240 FPGA along with DDR memory and other optional circuitry in their designs. It provides nine rails of lower voltage with an input of 12 volts. The use of PTH T2 modules provides a high-performance solution for good transient response and tight regulation while conserving valuable board space. - High-Temperatures Soldering Requirements for Plug-in Power, Surface-Mount Pdts (Rev. A)PDF, 112 Кб, Версия: A, Файл опубликован: 13 авг 2009
Серия: PTH08T220W (6)
- PTH08T220WAD PTH08T220WAH PTH08T220WAS PTH08T220WAST PTH08T220WAZ PTH08T220WAZT
- Semiconductors > Power Management > Power Modules > Non-Isolated Module > Step-Down (Buck) Module
