HRP-N3 - серия источников питания с максимальной пиковой мощностью в 350% от MEAN WELL
Datasheet Texas Instruments XCC2640R2FTWRGZTQ1 — Даташит
СерияCC2640R2F-Q1
МодельXCC2640R2FTWRGZTQ1
Automotive Qualified SimpleLinkв„ў BluetoothВ® low energy Wireless MCU 48-VQFN -40 to 105
CC2640R2F-Q1 SimpleLinkв„ў BluetoothВ® low energy Wireless MCU for Automotive datasheet
PDF, 2.2 Мб, Версия: A, Файл опубликован: 29 авг 2017
Электромеханические реле Hongfa – надежность и качество 19 января 2023
Pin48
Package TypeRGZ
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
CarrierSMALL T&R
Width (мм)7
Length (мм)7
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
ADC Resolution(Bits)12
CPUARM Cortex-M3
Device TypeWireless MCU
Flash (KB)128
GPIO31
Operating Temperature Range(C)-40 to 105
Package GroupVQFN
RAM(KB)20
Security EnablerCryptographic Acceleration
Debug Security
Device Identity
Software IP Protection
Standby Current(uA)1.1
TechnologyBluetooth low energy (BLE)
Proprietary
RoHSTBD
  • Development Kits: LAUNCHXL-CC2640R2
    SimpleLinkв„ў BluetoothВ® low energy CC2640R2F wireless MCU LaunchPadв„ў development kit
  • JTAG Emulators/ Analyzers: TMDSEMU110-U
    XDS110 JTAG Debug Probe
    XDS200 USB Debug Probe
  • Increase RAM Size on the CC2640R2F Bluetooth low energy Wireless MCU
    PDF, 130 Кб, Файл опубликован: 23 мар 2017
    This application report documents ways to increase the available random access memory (RAM) for your application on the CC2640R2F SimpleLinkв„ў Bluetooth low energy microcontroller. By moving initialized data or compiled code from the SRAM into other parts of the memory, the available SRAM is increased. This application report also highlights some of the tools found in the SimpleLink CC2640R2
  • Hardware Migration From CC2640F128 to CC2640R2F
    PDF, 27 Кб, Файл опубликован: 31 янв 2017
    This application report describes the required changes when moving from the SimpleLinkв„ў CC2640F128 to the SimpleLink CC2640R2F wireless MCU.
  • Measuring Bluetooth Low Energy Power Consumption (Rev. C)
    PDF, 5.0 Мб, Версия: C, Файл опубликован: 10 янв 2017
    This application report describes the setup and procedures to measure power consumption on CC2650,CC2640 and CC2640R2F devices operating as a Bluetooth® low energy “Peripheral” device.
  • Running BluetoothВ® Low Energy on CC2640 Without 32 kHz Crystal (Rev. B)
    PDF, 82 Кб, Версия: B, Файл опубликован: 5 апр 2017
    This application report explains how you can configure the SimpleLinkв„ў Bluetooth low energy CC2640 wireless MCU, CC2640R2F wireless MCU and multi-standard CC2650 wireless MCU to run the Bluetooth low energy (BLE) software stack without the need for a 32 kHz crystal.
  • Using the Wireless SimpleLink CC26xx in Ext Regulator Mode With the TPS62740
    PDF, 301 Кб, Файл опубликован: 19 ноя 2015
    This application report describes the set-up and expected performance when using the CC2640 in external regulator mode together with the TPS62740. Although this application report focuses on the CC2640 and BluetoothВ® Smart applications, the solutions provided are also applicable for the entire CC26xx family and its supported protocols. Note that waveforms and power consumption measurement r
  • Using GCC/GDB With SimpleLink CC26xx
    PDF, 1.0 Мб, Файл опубликован: 23 фев 2015
    This application report describes how to set up an open source software-based development environment for the SimpleLink CC26xx and CC13xx wireless MCUs using Eclipse as integrated development environment (IDE).
  • CC2640 Wireless MCU DC Supply Evaluation
    PDF, 1.3 Мб, Файл опубликован: 5 окт 2015
    CC2640 Wireless MCU DC Supply Evaluation /WTBU/WCS/Bluetooth/AppReports/SWRA494/SWRA494
  • Crystal Oscillator and Crystal Selection for the CC26xx and CC13xx Wireless MCUs (Rev. F)
    PDF, 886 Кб, Версия: F, Файл опубликован: 10 авг 2017
  • ETSI EN 300 328 Blocking Test for Bluetooth Low Energy
    PDF, 2.4 Мб, Файл опубликован: 8 фев 2017
    This application report describes the setup and procedure used to measure the new ETSI EN receiver (RX) blocking test added to version v2.1.1 of the ETSI EN 300 328 harmonized standard.
  • CC2538/CC26xx Bootloader Interface (Rev. A)
    PDF, 277 Кб, Версия: A, Файл опубликован: 21 май 2015
    This application report provides a brief overview on the serial bootloader that resides in ROM on the CC2538 and CC13xx/CC26xx devices. This document shows how the bootloader protocol can be used to perform basic operations like erasing and programming the flash of the devices. The device bootloaders support universal asynchronous receiver/transmitter (UART) and serial peripheral interface (SPI) a
  • CC-Antenna-DK2 and Antenna Measurements Summary
    PDF, 14.8 Мб, Файл опубликован: 3 мар 2016
    The purpose of the antenna development kit (CC-Antenna-DK2) is to ease the decision of which type of low-cost antenna can be implemented as well as give an estimation of the performance that can be achieved.
Серия: CC2640R2F-Q1 (3)
  • Semiconductors > Microcontrollers (MCU) > SimpleLink MCUs > SimpleLink wireless MCUs > SimpleLink CC264x BLE
На английском языке: Datasheet Texas Instruments XCC2640R2FTWRGZTQ1
Публикации по теме
