Datasheet Texas Instruments TPS54917RUVT — Даташит
Серия | TPS54917 |
Модель | TPS54917RUVT |
Входное напряжение от 3 В до 4 В, ток 9 А, синхронный понижающий преобразователь SWIFT™ 34-VQFN от -40 до 125
TPS54917 3-V to 4-V Input, 9-A, Small Synchronous Buck Switcher With Integrated FETs (SWIFTв„ў) datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 23 дек 2016
Купить TPS54917RUVT на РадиоЛоцман.Цены — от 234 до 988 ₽ 18 предложений от 11 поставщиков Step-Down Regulator 3V to 4V, 9A, 1.6MHz Synchronous Step Down SWIFT Converter Conv DC-DC Single Step Down 3V to 4V 34Pin... | |||
TPS54917RUVT Texas Instruments | 234 ₽ | ||
TPS54917RUVT Texas Instruments | 319 ₽ | ||
TPS54917RUVT Texas Instruments | 988 ₽ | ||
TPS54917RUVT | по запросу |
Pin | 34 |
Package Type | RUV |
Industry STD Term | VQFN |
JEDEC Code | R-PQFP-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | 54917 |
Width (мм) | 7 |
Length (мм) | 3.5 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Control Mode | Voltage Mode |
Duty Cycle(Max) | 90 % |
Iout(Max) | 9 A |
Iq(Typ) | 11 мА |
Package Group | VQFN |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Enable,Frequency Synchronization,Power Good,Synchronous Rectification |
Switching Frequency(Max) | 1600 kHz |
Switching Frequency(Min) | 280 kHz |
Тип | Converter |
Vin(Max) | 4 В |
Vin(Min) | 3 В |
Vout(Max) | 2.5 В |
Vout(Min) | 0.9 В |
- Evaluation Modules & Boards: TPS54917EVM-367
9A, 3V to 4V Vin, SWIFTВ™ Converter Evaluation Module
- Understanding Thermal Dissipation and Design of a HeatsinkPDF, 59 Кб, Файл опубликован: 4 май 2011
Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
Серия: TPS54917 (2)
- TPS54917RUVR TPS54917RUVT
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
