Datasheet Texas Instruments UC3875NG4 — Даташит
Серия | UC3875 |
Модель | UC3875NG4 |
Резонансный регулятор фазового сдвига 20-PDIP от 0 до 70
Phase Shift Resonant Controller datasheet
PDF, 5.7 Мб, Версия: C, Файл опубликован: 24 май 2007
Купить UC3875NG4 на РадиоЛоцман.Цены — от 529 до 1 270 ₽ 11 предложений от 11 поставщиков TEXAS INSTRUMENTS UC3875NG4Phase Shift Controller, 20V-11V supply, 1 MHz, 2.6V/500mA out, DIP-20 | |||
UC3875NG4 Texas Instruments | 529 ₽ | ||
UC3875NG4 Texas Instruments | 827 ₽ | ||
UC3875NG4 Texas Instruments | 1 026 ₽ | ||
UC3875NG4 Texas Instruments | по запросу |
Pin | 20 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 20 |
Carrier | TUBE |
Маркировка | UC3875N |
Width (мм) | 6.35 |
Length (мм) | 24.33 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
- Evaluation Modules & Boards: UCC3895EVM-001
UCC3895 Evaluation Module
- A Comparison Between the BiCMOS UCC3895 Phase Shift Controller and the UC3875PDF, 21 Кб, Файл опубликован: 22 фев 2001
This application report compares the BiCMOS UCC3895 to its bipolar predecessors, the UC3875/6/7/8 family and the UC3879 controller. All of these integrated circuits provide the control and drive signals needed to implement a full-bridge converter using phase-shifted control. The UCC3895 represents the latest offering in the Texas Instruments line of phase-shift controllers, incorporating a feature - DN-63 The Current-Doubler Rectifier: An Alternative Rectification TechniquePDF, 81 Кб, Файл опубликован: 12 янв 2001
The UC3875, UC3879, and UC3895 families of ICs control a bridge power stage by phase-shifting the switching of one half-bridge with respect to the other. This method allows constant-frequency pulse-width modulation in combination with resonant, zero-voltage switching for high efficiency performance. These ICs can be configured to provide control in either voltage mode or current mode operation, wi - Phase Shifted Full Bridge, Zero Voltage Transition Design Considerations (Rev. A)PDF, 393 Кб, Версия: A, Файл опубликован: 22 янв 2011
This Application Note will highlight the design considerations incurred in a high frequency power supply using the Phase Shifted Resonant PWM control technique. An overview of this switching technique including comparisons to existing fixed frequency non-resonant and variable frequency Zero Voltage Switching is included. Numerous design equations and associated voltage, current and timing waveform - Synchronous Rectifiers of a Current DoublerPDF, 207 Кб, Файл опубликован: 27 фев 2003
Driving a current doubler synchronous rectification output stage can be a very complex task, especially for a phase shifted full bridge topology. However, using the A and B outputs of the UCC3895 along with the UCC37324 dual 4-A MOSFET driver, direct PWM control of a synchronous rectifier current doubler output stage achieves. This technique provides the proper gating and timing signals necessary - Current Doubler Rectifier Offers Ripple Current CancellationPDF, 116 Кб, Файл опубликован: 21 сен 2004
Серия: UC3875 (8)
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
