Datasheet Texas Instruments OPA356AIDR — Даташит
Серия | OPA356 |
Модель | OPA356AIDR |
2,5 В, 200 МГц GBW, одиночный КМОП-операционный усилитель, 8-SOIC, от -40 до 125
OPA356, 2356: 200MHz, Video CMOS Operational Amplifier datasheet
PDF, 817 Кб, Версия: A, Файл опубликован: 7 ноя 2001
Купить OPA356AIDR на РадиоЛоцман.Цены — от 56 до 298 ₽ 24 предложений от 13 поставщиков High Speed Operational Amplifiers 2.5V 200MHz GBW CMOS Single Op Amp | |||
OPA356AIDR Texas Instruments | 56 ₽ | ||
OPA356AIDR Texas Instruments | 77 ₽ | ||
OPA356AIDR Texas Instruments | по запросу | ||
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | OPA | 356A |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
2nd Harmonic | 81 dBc |
3rd Harmonic | 93 dBc |
Acl, min spec gain | 1 V/V |
BW @ Acl | 450 МГц |
Iq per channel(Max) | 14 мА |
Количество каналов | 1 |
Offset Voltage Drift (+/-)(Max) | 7 uV/Degrees Celsius |
Output Current(Typ) | 100 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Settling Time (0.1%)(Typ) | 30 нс |
Slew Rate(Typ) | 360 V/us |
Total Supply Voltage(Max) | 5.5 В |
Total Supply Voltage(Min) | 2.5 В |
Vn at Flatband(Typ) | 5.8 нВ/rtГц |
Vos(Max) | 9 мВ |
- Evaluation Modules & Boards: EVMX777G-01-20-00
J6Entry/RSP Infotainment (CPU+Display+JAMR3) Evaluation Module
- High-Voltage Signal Conditioning for Differential ADCsPDF, 125 Кб, Файл опубликован: 14 июн 2004
Analog designers are frequently required to convert high-voltage signals to levels acceptable to low-voltage data converters with differential inputs. This paper describes solutions for this common task using modern amplifiers and typical power supplies. Three examples of conditioning В±10V bipolar signals for low-voltage analog-to-digital converters (ADCs) are shown: a single-supply design, - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA356 (7)
- Semiconductors > Amplifiers > Special Function Amplifiers > Transimpedance Amplifiers
