Datasheet Texas Instruments INA105KUE4 — Даташит
Серия | INA105 |
Модель | INA105KUE4 |
Прецизионный дифференциальный усилитель с единичным коэффициентом усиления 8-SOIC от -40 до 85
Precision Unity Gain Differential Amplifier datasheet
PDF, 710 Кб, Файл опубликован: 27 сен 2000
Купить INA105KUE4 на РадиоЛоцман.Цены — от 90 до 729 ₽ 9 предложений от 9 поставщиков TEXAS INSTRUMENTS - INA105KUE4 - DIFFERENTIAL AMPLIFIER, 1MHZ, 3V/uS, SOIC8 | |||
INA105KUE4 | 90 ₽ | ||
INA105KUE4 Texas Instruments | 325 ₽ | ||
INA105KUE4 Texas Instruments | 729 ₽ | ||
INA105KUE4 Texas Instruments | по запросу |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 75 | 75 |
Carrier | TUBE | TUBE |
Маркировка | INA | 105U |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
CMRR(Min) | 86 дБ |
Common Mode Input High(Max) | 20 В |
Common Mode Input High(Min) | 20 В |
Common Mode Input Low(Min) | -20 В |
Gain | 1 V/V |
Gain Drift(Max) | 1 ppm/C |
Gain Error (+/-)(Max) | 0.01 % |
Gain(Max) | 1 V/V |
Gain(Min) | 1 V/V |
Input Offset (+/-)(Max) | 250 uV |
Iq(Typ) | 1.5 мА |
Количество каналов | 1 |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rating | Catalog |
Slew Rate(Typ) | 3 V/us |
Small Signal Bandwidth(Typ) | 1 МГц |
Vs(Max) | 36 В |
Vs(Min) | 10 В |
- Make a -10V to +10V Adjustable Precision Voltage Source (Rev. A)PDF, 50 Кб, Версия: A, Файл опубликован: 18 май 2015
- Simple Circuit Delivers 38Vp-p at 5A from 28V Unipolar SupplyPDF, 26 Кб, Файл опубликован: 27 сен 2000
Since the first analog IC requiring bipolar supplies was developed, people have been trying to operate them from unipolar supplies. Not only do the headroom (VS - VOUTMAX) requirements come into play, but with a unipolar supply typically come unipolar outputs. To get bipolar output swings from a unipolar supply, drive the load differentially and create a reference signal wh - Boost Amplifier Output Swing With Simple ModificationPDF, 46 Кб, Файл опубликован: 27 сен 2000
In many applications it is desirable for the output of an amplifier to swing close to its power supply rails. Most amplifiers only guarantee an output swing of В±10V to В±12V when operating on standard В±15V power supplies. With the addition of four resistors and a pair of garden-variety transistors, the INA105 or INA106 difference amplifiers can be modified to provide nearly a f - Extending the Common-Mode Range of Difference AmplifiersPDF, 49 Кб, Файл опубликован: 27 сен 2000
Extending the common-mode range of difference amplifiers allows their use in a wider variety of reduced power-supply applications. The INA117 has a specified common-mode input range of В±200V when operating on standard В±15V power supplies. At power-supply voltages above В±13V, the INA117 input range is limited to В±200V by the power capabilities of its internal input resis - Single-Supply Operation of Isolation AmplifiersPDF, 46 Кб, Файл опубликован: 27 сен 2000
For simplicity, many systems are designed to operate from a single external power supply. In battery powered systems such as aircraft and automotive, it's often a requirement. Isolation amplifiers such as the ISO120 and ISO122 can be easily modified for input side single-supply operation with the addition of an INA105 difference amplifier. With ISO amps, it's the isolated input side power supply w - Level Shifting Signals with Differential AmplifiersPDF, 23 Кб, Файл опубликован: 27 сен 2000
The INA105 is a unity gain differential amplifier consisting of a premium grade operational amplifier and an on-chip precision resistor network. The self-contained INA105 makes it ideal for many applications. One such application is precision level shifting. - AC Coupling Instrumentation and Difference AmplifiersPDF, 38 Кб, Файл опубликован: 27 сен 2000
The need to glean AC signals from DC in the presence of common-mode noise frequently occurs in signal conditioning applications. AC coupling to an instrumentation amplifier (IA) or difference amplifier can be used to accurately extract the AC signal while rejecting DC and common-mode noise. - Implementation and Applications of Current Sources and Current ReceiversPDF, 427 Кб, Файл опубликован: 27 сен 2000
This application guide is intended as a source book for the design and application of: Current sourcesCurrent sinksFloating current sourcesVoltage-to-current converters(transconductance amplifiers)Current-to-current converters (current mirrors)Current-to-voltage converters(transimpedance amplifiers)
Серия: INA105 (8)
- INA105AM INA105BM INA105KP INA105KPG4 INA105KU INA105KU/2K5 INA105KU/2K5E4 INA105KUE4
- Semiconductors > Amplifiers > Difference Amplifiers
