Datasheet Texas Instruments UC3875DWPTR — Даташит
Серия | UC3875 |
Модель | UC3875DWPTR |
Резонансный регулятор фазового сдвига 28-SOIC от 0 до 70
Phase Shift Resonant Controller datasheet
PDF, 5.7 Мб, Версия: C, Файл опубликован: 24 май 2007
Купить UC3875DWPTR на РадиоЛоцман.Цены — от 394 до 1 700 ₽ 16 предложений от 12 поставщиков Soft Sw PWM Cntrlr 4-OUT PH SHIFT RES 1MHz 28-Pin SOIC T/R | |||
UC3875DWPTR Texas Instruments | 394 ₽ | ||
UC3875DWPTR Texas Instruments | 522 ₽ | ||
UC3875DWPTR Texas Instruments | по запросу | ||
Pin | 28 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | UC3875DWP |
Width (мм) | 7.5 |
Length (мм) | 17.9 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
- Evaluation Modules & Boards: UCC3895EVM-001
UCC3895 Evaluation Module
- A Comparison Between the BiCMOS UCC3895 Phase Shift Controller and the UC3875PDF, 21 Кб, Файл опубликован: 22 фев 2001
This application report compares the BiCMOS UCC3895 to its bipolar predecessors, the UC3875/6/7/8 family and the UC3879 controller. All of these integrated circuits provide the control and drive signals needed to implement a full-bridge converter using phase-shifted control. The UCC3895 represents the latest offering in the Texas Instruments line of phase-shift controllers, incorporating a feature - DN-63 The Current-Doubler Rectifier: An Alternative Rectification TechniquePDF, 81 Кб, Файл опубликован: 12 янв 2001
The UC3875, UC3879, and UC3895 families of ICs control a bridge power stage by phase-shifting the switching of one half-bridge with respect to the other. This method allows constant-frequency pulse-width modulation in combination with resonant, zero-voltage switching for high efficiency performance. These ICs can be configured to provide control in either voltage mode or current mode operation, wi - Phase Shifted Full Bridge, Zero Voltage Transition Design Considerations (Rev. A)PDF, 393 Кб, Версия: A, Файл опубликован: 22 янв 2011
This Application Note will highlight the design considerations incurred in a high frequency power supply using the Phase Shifted Resonant PWM control technique. An overview of this switching technique including comparisons to existing fixed frequency non-resonant and variable frequency Zero Voltage Switching is included. Numerous design equations and associated voltage, current and timing waveform - Synchronous Rectifiers of a Current DoublerPDF, 207 Кб, Файл опубликован: 27 фев 2003
Driving a current doubler synchronous rectification output stage can be a very complex task, especially for a phase shifted full bridge topology. However, using the A and B outputs of the UCC3895 along with the UCC37324 dual 4-A MOSFET driver, direct PWM control of a synchronous rectifier current doubler output stage achieves. This technique provides the proper gating and timing signals necessary - Current Doubler Rectifier Offers Ripple Current CancellationPDF, 116 Кб, Файл опубликован: 21 сен 2004
Серия: UC3875 (8)
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
