Datasheet Texas Instruments TLC27L2MJG — Даташит
Серия | TLC27L2M |
Модель | TLC27L2MJG |
Lincmos(Tm) Прецизионный двойной операционный усилитель 8-CDIP от -55 до 125
LinCMOS Precision Dual Operational Amplifiers datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 25 окт 2005
LinCMOSE PRECISION DUAL OPERATIONAL AMPLIFIERS | |||
TLC27L2MJG Texas Instruments | по запросу |
Pin | 8 |
Package Type | JG |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Width (мм) | 6.67 |
Length (мм) | 9.6 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Additional Features | Vos Adj Pin |
Архитектура | CMOS |
CMRR(Min)(dB) | 65 |
CMRR(Typ)(dB) | 94 |
GBW(Typ)(MHz) | 0.085 |
Input Bias Current(Max)(pA) | 60 |
Iq per channel(Max)(mA) | 0.017 |
Iq per channel(Typ)(mA) | 0.01 |
Number of Channels(#) | 2 |
Offset Drift(Typ)(uV/C) | 1.4 |
Operating Temperature Range(C) | -55 to 125 |
Output Current(Typ)(mA) | 1 |
Package Group | SOIC |
Package Size: mm2:W x L (PKG) | See datasheet (CDIP) |
Rail-to-Rail | In to V- |
Rating | Military |
Slew Rate(Typ)(V/us) | 0.03 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 16 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 4 |
Vn at 1kHz(Typ)(nV/rtHz) | 68 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 10 |
RoHS | Не совместим |
Серия: TLC27L2M (8)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Ultra-Low-Power Op Amps (<=250uA)
