Datasheet Texas Instruments TL5001MJGB — Даташит
Серия | TL5001M |
Модель | TL5001MJGB |
ШИМ-контроллер с широким входным диапазоном 8-CDIP от -55 до 125
Pulse-Width-Modulation Control Circuits datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 31 янв 2002
Купить TL5001MJGB на РадиоЛоцман.Цены — от 905 до 1 222 ₽ 7 предложений от 7 поставщиков Оборудование для монтажа светодиодов TowerLight, 50mm Short Base, Plastic | |||
TL5001MJGB Texas Instruments | 905 ₽ | ||
TL5001MJGB Texas Instruments | 1 213 ₽ | ||
TL5001MJGB Texas Instruments | 1 222 ₽ | ||
TL5001MJGB Altech | по запросу |
Pin | 8 | 8 |
Package Type | JG | JG |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | 9958301QPA | TL5001M |
Width (мм) | 6.67 | 6.67 |
Length (мм) | 9.6 | 9.6 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
Duty Cycle(Max) | 100 % |
Iout(Max) | 3 A |
Iq(Typ) | 1.1 мА |
Package Group | CDIP |
Rating | Military |
Regulated Outputs | 1 |
Switching Frequency(Max) | 400 kHz |
Switching Frequency(Min) | 50 kHz |
Тип | Controller |
Vin(Max) | 40 В |
Vin(Min) | 3.6 В |
Vout(Max) | 50 В |
Vout(Min) | 1 В |
RoHS | See ti.com |
- Examples Of Applications With The Pulse Width Modulator TL5001PDF, 462 Кб, Файл опубликован: 1 янв 1997
Switched-mode techniques are used more and more nowadays for the design of power supplies. Switch mode power supplies have considerably higher efficiency when compared to designs employing linear regulators, and can be used for higher output powers. The rectified input voltage in a switching regulator is chopped by means of a switch. The LC network after the switch smoothes this voltage, resulting - Designing with the TL5001 PWM Controller (Rev. A)PDF, 265 Кб, Версия: A, Файл опубликован: 1 сен 1995
Electrical and electronic products required to be lighter, smaller, use less power, and cost less. Manufacturers are turning to small high-frequency dc-to-dc converters for the power supply solution. The TL5001, pulse-width modulator (PWM) control integrated circuit, when combined with a few external components, can implement the converters and operate at frequencies to 400 kHz. This document p - Off-Line SMPS Failure Modes PWM Switchers and DC-DC ConvertersPDF, 71 Кб, Файл опубликован: 22 мар 2000
Today's voltage regulator modules (VRMs) employ off-line SMPS techniques. Traditionally, they are usually discarded when they fail because they are so challenging to debug and so inexpensive to replace. Investigation of these failed modules reveals some common failure modes. Some failures are caused by other systems' passive components that fail after repeated electrical stress. Recognizing these - Understanding Buck Power Stages In Switchmode Power SuppliesPDF, 173 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous - Understanding Boost Power Stages In Switchmode Power SuppliesPDF, 149 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o - Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TL5001M (3)
- 5962-9958301QPA TL5001MJG TL5001MJGB
- Semiconductors > Space & High Reliability > Power Management Products > Non-isolated DC/DC Switching Regulators
