Datasheet Texas Instruments TPS62402DRCR — Даташит
Серия | TPS62402 |
Модель | TPS62402DRCR |
Двойной понижающий преобразователь, 400 мА и 600 мА, 2,25 МГц с 1-проводным интерфейсом в QFN 10-VSON от -40 до 85
TPS6240x 2.25-MHz 400-mA and 600-mA Dual Step-Down Converter In Small 3-mm x 3-mm VSON Package datasheet
PDF, 1.8 Мб, Версия: F, Файл опубликован: 30 июл 2014
Купить TPS62402DRCR на РадиоЛоцман.Цены — от 56 до 336 ₽ 21 предложений от 13 поставщиков Buck Switching Regulator IC Positive Programmable (Fixed) 1.2V, 1.8V (3.3V) 2 Output 400mA, 600mA 10-VFDFN Exposed Pad | |||
TPS62402DRCR Texas Instruments | 56 ₽ | ||
TPS62402DRCR Texas Instruments | 69 ₽ | ||
TPS62402DRCR Texas Instruments | по запросу | ||
Pin | 10 |
Package Type | DRC |
Industry STD Term | VSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | BYH |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Control Mode | Voltage Mode |
Duty Cycle(Max) | 100 % |
Iout(Max) | 0.4 A |
Iq(Typ) | 0.032 мА |
Package Group | VSON |
Rating | Catalog |
Regulated Outputs | 2 |
Special Features | Dynamic Voltage Scaling,Enable,Light Load Efficiency,Synchronous Rectification |
Switching Frequency(Max) | 2500 kHz |
Switching Frequency(Min) | 2000 kHz |
Тип | Converter |
Vin(Max) | 6 В |
Vin(Min) | 2.5 В |
Vout(Max) | 1.8 В |
Vout(Min) | 1.2 В |
- TMS320F28xx and TMS320F28xxx DSP Power Reference Design (Rev. A)PDF, 125 Кб, Версия: A, Файл опубликован: 10 апр 2008
This reference design takes into account the voltage, current, and start-up requirements of the TMS320F280x Digital Signal Processor (DSP) families. The operating input voltage ranges from 3.4 V to 6 V. This design is a high-efficiency solution that provides two voltage rails (1.8-V core supply and 3.3-V I/O supply) and an active-low reset signal to the DSP. This design can be easily adapted to fi - Optimizing Transient Response of Internally Compensated DC-DC Converters (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 11 май 2015
- Five steps to a great PCB layout for a step-down converterPDF, 162 Кб, Файл опубликован: 29 янв 2015
- Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
- Testing tips for applying external power to supply outputs without an input voltPDF, 110 Кб, Файл опубликован: 24 окт 2016
- Basic Calculation of a Buck Converter's Power Stage (Rev. B)PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
- Extending the Soft Start Time Without a Soft Start Pin (Rev. B)PDF, 387 Кб, Версия: B, Файл опубликован: 15 июн 2017
- QFN and SON PCB Attachment (Rev. B)PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
- IQ: What it is what it isn’t and how to use itPDF, 198 Кб, Файл опубликован: 17 июн 2011
- Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
Серия: TPS62402 (4)
- TPS62402DRCR TPS62402DRCRG4 TPS62402DRCT TPS62402DRCTG4
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
