Datasheet Texas Instruments LM5045MHX/NOPB — Даташит
Серия | LM5045 |
Модель | LM5045MHX/NOPB |
Полномостовой ШИМ-контроллер со встроенными драйверами MOSFET 28-HTSSOP от -40 до 125
LM5045 Full-Bridge PWM Controller With Integrated MOSFET Drivers datasheet
PDF, 1.6 Мб, Версия: H, Файл опубликован: 28 янв 2015
Купить LM5045MHX/NOPB на РадиоЛоцман.Цены — от 162 до 744 ₽ 19 предложений от 12 поставщиков Current Mode PWM Controller 2A 100kHz to 2000kHz 28Pin HTSSOP EP T/R | |||
LM5045MHX/NOPB Texas Instruments | 162 ₽ | ||
LM5045MHX/NOPB Texas Instruments | 222 ₽ | ||
LM5045MHX/NOPB Texas Instruments | по запросу | ||
Pin | 28 | 28 |
Package Type | PWP | PWP |
Industry STD Term | HTSSOP | HTSSOP |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | LM5045 | MH |
Width (мм) | 4.4 | 4.4 |
Length (мм) | 9.7 | 9.7 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1.2 | 1.2 |
Control Method | Current,Voltage |
Duty Cycle(Max) | 50 % |
Frequency(Max) | 2000 kHz |
Frequency(Min) | 100 kHz |
Gate Drive(Typ) | 1.5,2 A |
Package Group | HTSSOP |
Rating | Catalog |
Special Features | HV Start-up,Multi-topology,Synchronization Pin |
Topology | Full-Bridge,Half-Bridge,Push-Pull |
UVLO Thresholds On/Off | Programmable/1.25V В |
Vin(Max) | 100 В |
Vin(Min) | 14 В |
- Evaluation Modules & Boards: LM5045EVAL
Evaluation Board for the LM5045
- AN-2213 LM5045 Based 240W Power Converter Using Full-Wave (Rev. A)PDF, 5.6 Мб, Версия: A, Файл опубликован: 6 май 2013
The LM5045 based 240W reference board is designed to evaluate the performance of the full-waverectification scheme on the secondary side. The reference board is designed in an industry standardquarter brick footprint. - Applying I2C-Compatible Temperature Sensors in Systems With Slow Clock Edges (Rev. A)PDF, 33 Кб, Версия: A, Файл опубликован: 6 май 2013
This Application Note describes a method of interfacing a given microcontroller with a Texas Instruments digital temperature sensor.
Серия: LM5045 (4)
- LM5045MH/NOPB LM5045MHX/NOPB LM5045SQ/NOPB LM5045SQX/NOPB
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
