Datasheet Texas Instruments ADS802E/1K — Даташит
Серия | ADS802 |
Модель | ADS802E/1K |
12-битный АЦП SE/Diff, 10 MSPS. Внутренние ссылки, контакты совместимы с ADS800/1 28-SSOP от -40 до 85
12-Bit, 10MHz Sampling Analog-To-Digital Converter datasheet
PDF, 358 Кб, Версия: B, Файл опубликован: 14 фев 2005
12-Bit, 10MHz Sampling ANALOG-TO-DIGITAL CONVERTER | |||
ADS802E/1K | по запросу | ||
ADS802E/1K Texas Instruments | по запросу |
Pin | 28 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Width (мм) | 5.3 |
Length (мм) | 10.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | ADS804E/1K |
Replacement Code | F |
# Input Channels | 1 |
Analog Voltage AVDD(Max)(V) | 5.25 |
Analog Voltage AVDD(Min)(V) | 4.75 |
Approx. Price (US$) | 19.33 | 1ku |
Архитектура | Pipeline |
Digital Supply(Max)(V) | 5.25 |
Digital Supply(Min)(V) | 4.75 |
INL(Max)(+/-LSB) | 2.75 |
Input Range(Max)(V) | 3.25 |
Input Range(Min)(V) | 1.25 |
Тип входа | Differential Single-Ended |
Interface | Parallel |
Operating Temperature Range(C) | -40 to 85 |
Package Group | SOIC |
Package Size: mm2:W x L (PKG) | 28SOIC: 184 mm2: 10.3 x 17.9(SOIC) |
Power Consumption(Typ)(mW) | 260 |
Rating | Catalog |
Reference Mode | Ext Int |
Resolution(Bits) | 12 |
SINAD(dB) | 66 |
SNR(dB) | 67 |
Sample Rate (max)(SPS) | 10MSPS |
RoHS | Не совместим |
- Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Interleaving Analog-to-Digital ConvertersPDF, 64 Кб, Файл опубликован: 2 окт 2000
It is tempting when pushing the limits of analog-to-digital conversion to consider interleaving two or more converters to increase the sample rate. However, such designs must take into consideration several possible sources of error. - What Designers Should Know About Data Converter DriftPDF, 95 Кб, Файл опубликован: 2 окт 2000
Exactly how inaccurate will a change in temperature make an analog-to-digital or digital-to-analog converter? As designers are well aware, a 12-bit device may provide a much lower accuracy at its operating-temperature extremes, perhaps only to 9 or even 8 bits. But for lack of more precise knowledge, many play it safe (and expensive) and overspecify. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
- Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
