Datasheet Texas Instruments TLV1548MJB — Даташит
Серия | TLV1548M |
Модель | TLV1548MJB |
НИЗКОВОЛЬТНЫЙ 10-БИТ АНАЛОГО-ЦИФРОВОЙ ПРЕОБРАЗОВАТЕЛЬ С ПОСЛЕДОВАТЕЛЬНЫМ УПРАВЛЕНИЕМ И 8 ВХОДАМИ 20-CDIP от -55 до 125
Low-Voltage 10-Bit A-D Converters w/Serial Control and 4/8 Analog Inputs datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 21 янв 1999
Купить TLV1548MJB на РадиоЛоцман.Цены — от 18 734 до 62 474 ₽ 12 предложений от 9 поставщиков LOW-VOLTAGE 10-BIT ANALOG-TO-DIGITAL CONVERTERS WITH SERIAL CONTROL AND 4/8 ANALOG INPUTS | |||
TLV1548MJB Texas Instruments | 18 734 ₽ | ||
TLV1548MJB Texas Instruments | 19 386 ₽ | ||
TLV1548MJB Texas Instruments | 62 474 ₽ | ||
TLV1548MJB Texas Instruments | по запросу |
Pin | 20 | 20 | 20 |
Package Type | J | J | J |
Industry STD Term | CDIP | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 | 1 |
Carrier | TUBE | TUBE | TUBE |
Маркировка | 5962-9853801QR | TLV1548MJB | A |
Width (мм) | 6.92 | 6.92 | 6.92 |
Length (мм) | 24.2 | 24.2 | 24.2 |
Thickness (мм) | 4.57 | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 | 5.08 |
# Input Channels | 8 |
Analog Voltage AVDD(Max) | 5.5 В |
Analog Voltage AVDD(Min) | 2.7 В |
Архитектура | SAR |
Digital Supply(Max) | 5.5 В |
Digital Supply(Min) | 2.7 В |
INL(Max) | 1 +/-LSB |
Interface | SPI |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Power Consumption(Typ) | 1.05 mW |
Rating | Military |
Reference Mode | Ext |
Разрешение | 10 Bits |
Sample Rate (max) | 85kSPS SPS |
RoHS | See ti.com |
- Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: TLV1548M (4)
- 5962-9853801Q2A 5962-9853801QRA TLV1548MFKB TLV1548MJB
- Semiconductors > Space & High Reliability > Data Converter > Analog to Digital Converters
