Datasheet Texas Instruments OPA177GS/2K5E4 — Даташит
Серия | OPA177 |
Модель | OPA177GS/2K5E4 |
Прецизионный операционный усилитель 8-SOIC
Precision Operational Amplifier datasheet
PDF, 296 Кб, Файл опубликован: 27 сен 2000
Купить OPA177GS/2K5E4 на РадиоЛоцман.Цены — от 87 до 253 ₽ 13 предложений от 10 поставщиков General Purpose Amplifier 1 Circuit 8-SOIC | |||
OPA177GS/2K5E4 Texas Instruments | 87 ₽ | ||
OPA177GS/2K5E4 Texas Instruments | 116 ₽ | ||
OPA177GS/2K5E4 Texas Instruments | 155 ₽ | ||
OPA177GS/2K5E4 Texas Instruments | от 253 ₽ |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | OPA | 177GS |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Additional Features | N/A |
Архитектура | FET |
CMRR(Min) | 115 дБ |
CMRR(Typ) | 140 дБ |
GBW(Typ) | 0.6 МГц |
Input Bias Current(Max) | 2000 pA |
Iq per channel(Max) | 2 мА |
Iq per channel(Typ) | 1.3 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 0.1 uV/C |
Output Current(Typ) | 22 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | Out |
Rating | Catalog |
Slew Rate(Typ) | 0.3 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 6 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 7.5 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.025 мВ |
- Diode-Based Temperature MeasurementPDF, 44 Кб, Файл опубликован: 27 сен 2000
Diodes are frequently used as temperature sensors in a wide variety of moderate-precision temperature measurement applications. The relatively high temperature coefficient of about -2mV/В°C is fairly linear. To make a temperature measurement system with a diode requires excitation, offsetting, and amplification. The circuitry can be quite simple. This Bulletin contains a collection of circuits - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Compensate Transimpedance Amplifiers Intuitively (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved. - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Boost Instrument Amp CMR With Common-Mode Driven SuppliesPDF, 175 Кб, Файл опубликован: 27 сен 2000
Ever-increasing demands are being placed on instrumentation amplifier (IA) performance. When standard IAs can not deliver the required performance, consider this enhanced version. Dramatic performance improvements can be achieved by operating the input amplifiers of a classical three-op-amp IA from common-mode driven sub-regulated power supplies. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA177 (10)
- OPA177FP OPA177FPG4 OPA177GP OPA177GPG4 OPA177GS OPA177GS/2K5 OPA177GS/2K5E4 OPA177GS/2K5G4 OPA177GSE4 OPA177GSG4
