Datasheet Texas Instruments LM2734XQMK/NOPB — Даташит
Серия | LM2734-Q1 |
Модель | LM2734XQMK/NOPB |
Тонкий регулятор постоянного тока SOT23, 1 А, понижающий нагрузку 6-SOT-23-THIN от -40 до 125
Datasheet LM2734
PDF, 1.6 Мб, Версия: J, Файл опубликован: 19 дек 2014, Страниц: 37
Thin SOT 1-A Load Step-Down DC-DC Regulator
Купить LM2734XQMK/NOPB на РадиоЛоцман.Цены — от 122 до 793 ₽ 18 предложений от 11 поставщиков Conv DC-DC 3V to 20V Step Down Single-Out 0.8V to 18V 1A Automotive 6Pin TSOT-23 T/R | |||
LM2734XQMK/NOPB Texas Instruments | 122 ₽ | ||
LM2734XQMK/NOPB Texas Instruments | 167 ₽ | ||
LM2734XQMK/NOPB Texas Instruments | от 406 ₽ | ||
LM2734XQMK/NOPB Texas Instruments | 451 ₽ |
Pin | 6 |
Package Type | DDC |
Industry STD Term | SOT-23-THIN |
JEDEC Code | R-PDSO-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | SUKB |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | .87 |
Pitch (мм) | .95 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
Control Mode | Current Mode |
Duty Cycle(Max) | 96 % |
Iout(Max) | 1 A |
Iq(Typ) | 2.1 мА |
Package Group | SOT-23-THIN |
Rating | Automotive |
Regulated Outputs | 1 |
Special Features | Enable,Light Load Efficiency,Pre-Bias Start-Up |
Switching Frequency(Max) | 1900 kHz |
Switching Frequency(Min) | 400 kHz |
Тип | Converter |
Vin(Max) | 20 В |
Vin(Min) | 3 В |
Vout(Max) | 18 В |
Vout(Min) | 0.8 В |
- Evaluation Modules & Boards: LM2734X-EVAL
Thin SOT23 1A Load Step-Down DC-DC Regulator Evaluation Module
- AN-1822 LMH6733 High Definition Video Transmission Over CAT5 (Rev. A)PDF, 247 Кб, Версия: A, Файл опубликован: 23 апр 2013
Sending component 1080i high definition (HD) video over CAT5 twisted-pair is achievable with a low-costsolution using Texas Instruments current feedback (CFB) LMH6733 operational amplifier. The LMH6733 isa triple operational amplifier with disable that has a slew rate of 1900 V/Ојs and a 2 Vpp output signalbandwidth of 480 MHz, making it ideal for this application. Component video signals are - Advanced Topics in Powering FPGAsPDF, 645 Кб, Файл опубликован: 22 мар 2007
- AN-1408 Designing Power Over Ethernet Using LM5070 and DP83865 (Rev. C)PDF, 631 Кб, Версия: C, Файл опубликован: 26 апр 2013
This application report provides a reference design for Power over Ethernet (PoE) on the Power Device(PD) side using Texas Instruments LM5070 and the physical layer device DP83865 Gig PHYTERв„ў V. - Power Management Considerations for FPGAs and ASICsPDF, 745 Кб, Файл опубликован: 22 мар 2007
Серия: LM2734-Q1 (6)
- LM2734XQMK/NOPB LM2734XQMKE/NOPB LM2734XQMKX/NOPB LM2734YQMK/NOPB LM2734YQMKE/NOPB LM2734YQMKX/NOPB
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
