Datasheet Texas Instruments UC3525BDWTR — Даташит
Серия | UC3525B |
Модель | UC3525BDWTR |
Регулирующие широтно-импульсные модуляторы 16-SOIC от 0 до 70
Regulating Pulse Width Modulators datasheet
PDF, 1.6 Мб, Файл опубликован: 5 сен 1999
Купить UC3525BDWTR на РадиоЛоцман.Цены — от 188 до 332 ₽ 13 предложений от 10 поставщиков Buck, Boost, Flyback, Forward Converter, Full-Bridge, Half-Bridge, Push-Pull Regulator Positive Output Step-Up, Step-Down, Step-Up/Step-Down DC-DC Controller IC 16-SOIC | |||
UC3525BDWTR Texas Instruments | от 188 ₽ | ||
UC3525BDWTR Texas Instruments | 201 ₽ | ||
UC3525BDWTR Texas Instruments | по запросу | ||
Pin | 16 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | UC3525BDW |
Width (мм) | 7.5 |
Length (мм) | 10.3 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Control Method | Voltage |
Duty Cycle(Max) | 49 % |
Frequency(Max) | 500 kHz |
Frequency(Min) | 0.1 kHz |
Gate Drive(Typ) | 0.4 A |
Рабочий диапазон температур | от 0 до 70 C |
Package Group | SOIC |
Rating | Catalog |
Special Features | Error Amplifier,Multi-topology,Soft Start,Synchronization Pin |
Topology | Boost,Buck,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull |
UVLO Thresholds On/Off | 7.0/6.5 В |
Vin(Max) | 35 В |
Vin(Min) | 8 В |
- DN-36 UC1525B/UC1527B Devices - Comparison Summary to UC1525A/27A DevicesPDF, 19 Кб, Файл опубликован: 5 сен 1999
The UC1525B and UC1527B are enhanced versions of the previous generation of UC1525A and UC1527A devices. They are pin-for-pin compatible and direct replacements for the A versions in almost all applications. The table in this design note compares the two sets of devices. Significant improvements have been made in the 5.1 V reference voltage and the output drivers as itemized in the table. - DN-62 Switching Power Supply Topology Voltage Mode vs. Current ModePDF, 66 Кб, Файл опубликован: 5 сен 1999
This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
Серия: UC3525B (6)
- UC3525BDW UC3525BDWG4 UC3525BDWTR UC3525BDWTRG4 UC3525BN UC3525BNG4
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
