Datasheet Texas Instruments ADS5296ARGCR — Даташит
Серия | ADS5296A |
Модель | ADS5296ARGCR |
10-разрядный, 200-MSPS, 4 или 8-канальный / 12-разрядный, 80-MSPS, 8-канальный АЦП 64-VQFN от -40 до 85
10-Bit, 200-MSPS, 4-Channel and 12-Bit, 80-MSPS, 8-Channel ADC . datasheet
PDF, 2.7 Мб, Файл опубликован: 30 окт 2013
Купить ADS5296ARGCR на РадиоЛоцман.Цены — от 6 830 до 7 345 ₽ 8 предложений от 8 поставщиков 10Bit, 200MSPS, 4Channel / 12Bit, 80MSPS, 8Channel ADC 64-VQFN -40℃ to 85℃ | |||
ADS5296ARGCR Texas Instruments | 6 830 ₽ | ||
ADS5296ARGCR Texas Instruments | 7 189 ₽ | ||
ADS5296ARGCR Texas Instruments | по запросу | ||
Pin | 64 |
Package Type | RGC |
Industry STD Term | VQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | ADS5296 |
Width (мм) | 9 |
Length (мм) | 9 |
Thickness (мм) | .88 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
# Input Channels | 4,8 |
Analog Input BW | 500 МГц |
Архитектура | Pipeline |
DNL(Max) | 0.95 +/-LSB |
DNL(Typ) | 0.3 +/-LSB |
ENOB | 11.3 Bits |
INL(Max) | 1.1 +/-LSB |
INL(Typ) | 0.2 +/-LSB |
Input Buffer | No |
Input Range | 2 Vp-p |
Interface | Serial LVDS |
Package Group | VQFN |
Package Size: mm2:W x L | 64VQFN: 81 mm2: 9 x 9(VQFN) PKG |
Power Consumption(Typ) | 560 mW |
Rating | Catalog |
Reference Mode | Ext,Int |
Разрешение | 10,12 Bits |
SFDR | 83 дБ |
SINAD | 83 дБ |
SNR | 70.3 дБ |
Sample Rate(Max) | 80,200 MSPS |
- Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS5296A (2)
- ADS5296ARGCR ADS5296ARGCT
- Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
