Datasheet Texas Instruments 5962-0254501VPA — Даташит
Серия | LMH6628QML-SP |
Модель | 5962-0254501VPA |
Двойной широкополосный малошумящий операционный усилитель с обратной связью по напряжению 8-CDIP от -55 до 125
Datasheet
6 предложений от 6 поставщиков Operational Amplifier, 2 Func, 2000uV Offset-Max, BIPolar, CDIP8 | |||
5962-0254501VPA Texas Instruments | 54 076 ₽ | ||
5962-0254501VPA National Semiconductor | по запросу | ||
5962-0254501VPA | по запросу |
Pin | 8 | 8 | 8 | 8 |
Package Type | NAB | NAB | NAB | NAB |
Industry STD Term | CDIP | CDIP | CDIP | CDIP |
JEDEC Code | R-CDIP-P | R-CDIP-P | R-CDIP-P | R-CDIP-P |
Package QTY | 40 | 40 | 40 | 40 |
Carrier | TUBE | TUBE | TUBE | TUBE |
Маркировка | LMH6628J-QV | 5962-02545 | 01VPA Q ACO | 01VPA Q >T |
Width (мм) | 6.502 | 6.502 | 6.502 | 6.502 |
Length (мм) | 10.16 | 10.16 | 10.16 | 10.16 |
Thickness (мм) | 4.064 | 4.064 | 4.064 | 4.064 |
Pitch (мм) | 2.54 | 2.54 | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 | 5.08 | 5.08 |
Mechanical Data | Скачать | Скачать | Скачать | Скачать |
2nd harmonic | 65 dBc |
3rd harmonic | 74 dBc |
@ MHz | 10 |
Acl, min spec gain | 1 V/V |
Архитектура | Voltage FB |
BW @ Acl | 300 МГц |
CMRR(Min) | 57 дБ |
CMRR(Typ) | 62 дБ |
GBW(Typ) | 300 МГц |
Input bias current(Max) | 10000000 pA |
Input bias current(Typ) | 700000 pA |
Iq per channel(Max) | 12.5 мА |
Iq per channel(Typ) | 9 мА |
Number of channels | 2 |
Offset drift(Typ) | 5 uV/C |
Operating temperature range | -55 to 125 C |
Output current(Typ) | 85 мА |
Package Group | CDIP|8,CFP|10 |
Package size: mm2:W x L | 8CDIP: 66 mm2: 6.502 x 10.16 (CDIP|8),10CFP: 42 mm2: 6.121 x 6.858 (CFP|10) PKG |
Radiation, SEL | Bipolar MeV.cm2/mg |
Radiation, TID(Typ) | 300 krad |
Rail-to-rail | No |
Rating | Space |
Slew rate(Typ) | 550 V/us |
Total supply voltage(Max) | 12 +5V=5, +/-5V=10 |
Total supply voltage(Min) | 5 +5V=5, +/-5V=10 |
Vn at 1 kHz(Typ) | 2 нВ/rtГц |
Vn at flatband(Typ) | 2 нВ/rtГц |
Vos (offset voltage @ 25 C)(Max) | 2 мВ |
RoHS | Не совместим |
Бессвинцовая технология (Pb Free) | Да |
Серия: LMH6628QML-SP (4)
- 5962-0254501VPA 5962F0254501VZA LMH6628J-QMLV LMH6628WGFQMLV
- Semiconductors > Analog and Mixed-Signal > Amplifiers > Operational amplifiers (op amps) > High-speed op amps (GBW>=50MHz)
59620254501VPA, 5962 0254501VPA
