Datasheet Texas Instruments UC1825AJ — Даташит
Серия | UC1825A |
Модель | UC1825AJ |
Высокоскоростной ШИМ-контроллер 16-CDIP от -55 до 125
UC2823x, UC2825x, UC3823x, UC3825x: High Speed PWM Controller datasheet
PDF, 922 Кб, Версия: E, Файл опубликован: 9 сен 2010
Купить UC1825AJ на РадиоЛоцман.Цены — от 1 237 до 11 426 ₽ 18 предложений от 18 поставщиков Current Mode PWM Controller 2A 1000kHz 16Pin CDIP Tube | |||
UC1825AJ Texas Instruments | 1 237 ₽ | ||
UC1825AJ Texas Instruments | 2 218 ₽ | ||
UC1825AJ Texas Instruments | 3 169 ₽ | ||
UC1825AJ Texas Instruments | 3 181 ₽ |
Pin | 16 |
Package Type | J |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Package QTY | 1 |
Carrier | TUBE |
Маркировка | UC1825AJ |
Width (мм) | 6.92 |
Length (мм) | 19.56 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Control Method | Current |
Duty Cycle(Max) | 50 % |
Frequency(Max) | 1000 kHz |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Special Features | Error Amplifier,Leading Edge Blanking,Soft Start,Synchronization Pin,Multi-topology |
Topology | Boost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull |
UVLO Thresholds On/Off | 9.2/8.4 В |
Vin(Max) | 22 В |
Vin(Min) | 8.4 В |
RoHS | See ti.com |
- U-128 The UC3823AB and UC3825AB Enhanced Generation of PWM ControllersPDF, 204 Кб, Файл опубликован: 5 сен 1999
The UC3823A and B and the UC3825A and B family of PWM control ICs are improved versions of the standard UC3823 & UC3825 family. This application note describes the enhancements incorporated in four new PWM control ICs: the UC3823A UC3823B UC3825A and UC3825B. Based on the industry standard UC3823 and UC3825 controllers this advanced generation features several key improvements in protection and
Серия: UC1825A (7)
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
