Datasheet Texas Instruments ADS803E — Даташит
Серия | ADS803 |
Модель | ADS803E |
12-разрядный аналого-цифровой преобразователь (АЦП) с быстродействием 5 MSPS, 28-SSOP от -40 до 85
ADS803: 12-Bit, 5MHz Sampling Analog-To-Digital Converter datasheet
PDF, 790 Кб, Версия: B, Файл опубликован: 18 июл 2002
Купить ADS803E на РадиоЛоцман.Цены — от 811 до 73 227 ₽ 27 предложений от 20 поставщиков 12Bit, 5MSPS ADC Int/Ext ef., flexible I/P between 2 and 5Vpp, Out of ange Indicator, pin comp. 28-SSOP -40℃ to 85℃... | |||
ADS803E/1K Texas Instruments | 811 ₽ | ||
ADS803E/1KG4 Texas Instruments | 1 223 ₽ | ||
ADS803E/1K Texas Instruments | от 2 701 ₽ | ||
ADS803IDBRHE | 73 227 ₽ |
Pin | 28 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 50 |
Carrier | TUBE |
Маркировка | ADS803E |
Width (мм) | 5.3 |
Length (мм) | 10.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
# Input Channels | 1 |
Analog Input BW | 270 МГц |
Архитектура | Pipeline |
DNL(Max) | 0.75 +/-LSB |
DNL(Typ) | 0.25 +/-LSB |
ENOB | 11 Bits |
INL(Max) | 2 +/-LSB |
INL(Typ) | 1 +/-LSB |
Input Buffer | No |
Input Range | 2,5 Vp-p |
Interface | Parallel CMOS,TTL |
Package Group | SSOP |
Package Size: mm2:W x L | 28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG |
Power Consumption(Typ) | 115 mW |
Rating | Catalog |
Reference Mode | Ext,Int |
Разрешение | 12 Bits |
SFDR | 82 дБ |
SINAD | 68 дБ |
SNR | 69 дБ |
Sample Rate(Max) | 5 MSPS |
- Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS803 (4)
- ADS803E ADS803E/1K ADS803U ADS803U/1K
- Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
