Datasheet Texas Instruments REG71055DDCTG4 — Даташит
Серия | REG71055 |
Модель | REG71055DDCTG4 |
60 мА, 5,5 В, повышающий/понижающий зарядный насос в ThinSOT-23 6-SOT-23-THIN от -40 до 85
REG710xx Buck-Boost Charge Pump with up to 60-mA Output Current datasheet
PDF, 1.2 Мб, Версия: H, Файл опубликован: 30 окт 2015
Купить REG71055DDCTG4 на РадиоЛоцман.Цены — от 55 до 76 ₽ 14 предложений от 11 поставщиков Charge Pump Switching Regulator IC Positive Fixed 5.5V 1 Output 60mA SOT-23-6 Thin, TSOT-23-6 | |||
REG71055DDCTG4 Texas Instruments | 55 ₽ | ||
REG71055DDCTG4 Texas Instruments | 66 ₽ | ||
REG71055DDCTG4 Texas Instruments | 76 ₽ | ||
REG71055DDCTG4 Texas Instruments | по запросу |
Pin | 6 |
Package Type | DDC |
Industry STD Term | SOT-23-THIN |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | R10H |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | .87 |
Pitch (мм) | .95 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
Iout(Max) | 0.06 A |
Iq(Typ) | 0.065 мА |
Package Group | SOT-23-THIN |
Rating | Catalog |
Special Features | Enable |
Switching Frequency(Max) | 1000 kHz |
Switching Frequency(Min) | 1000 kHz |
Topology | Buck/Boost |
Тип | Charge Pump |
Vin(Max) | 5.5 В |
Vin(Min) | 3 В |
Vout(Max) | 5.5 В |
Vout(Min) | 5.5 В |
- Optimizing Output Voltage Ripple for the REG710PDF, 56 Кб, Файл опубликован: 10 фев 2003
Many portable power applications require a power source that has buck?boost capability with low output ripple. For this application, the REG710 is a prime choice; however understanding the affects of the pump and output capacitors allows designers to take full advantage of theREG710?s capabilities in order to minimize output voltage ripple.
Серия: REG71055 (4)
- REG71055DDCR REG71055DDCRG4 REG71055DDCT REG71055DDCTG4
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost or Inverting Charge Pump (Inductorless)
