Datasheet Texas Instruments LM5030MMX/NOPB — Даташит
Серия | LM5030 |
Модель | LM5030MMX/NOPB |
ШИМ-контроллер двухтактного режима тока 100 В 10-VSSOP от -40 до 125
LM5030 100-V Push-Pull Current Mode PWM Controller datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 24 ноя 2015
Купить LM5030MMX/NOPB на РадиоЛоцман.Цены — от 80 до 466 ₽ 24 предложений от 13 поставщиков IC: PMIC; PWM controller; VSSOP10; -40÷125°C; Usup: 8÷15V; SMPS | |||
LM5030MMX/NOPB Texas Instruments | 80 ₽ | ||
LM5030MMX/NOPB Texas Instruments | 110 ₽ | ||
LM5030MMX/NOPB Texas Instruments | 119 ₽ | ||
LM5030MMX/NOPB Texas Instruments | по запросу |
Pin | 10 |
Package Type | DGS |
Industry STD Term | VSSOP |
JEDEC Code | S-PDSO-G |
Package QTY | 3500 |
Carrier | LARGE T&R |
Маркировка | S73B |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | 1.02 |
Pitch (мм) | .5 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Control Method | Current |
Duty Cycle(Max) | 49 % |
Frequency(Max) | 1000 kHz |
Frequency(Min) | 50 kHz |
Gate Drive(Typ) | 1.5 A |
Package Group | VSSOP |
Rating | Catalog |
Special Features | Multi-topology,Programmable Slope Compensation,Synchronization Pin |
Topology | Full-Bridge,Half-Bridge,Push-Pull |
UVLO Thresholds On/Off | 7.6/~5.95 В |
Vin(Max) | 90 В |
Vin(Min) | 14 В |
- Evaluation Modules & Boards: LM5030EVAL
100V Push-Pull Current Mode PWM Controller
- Is Your IGBT Gate-Driver Power Supply OptimizedPDF, 115 Кб, Файл опубликован: 12 мар 2015
Insulated Gate Bipolar Transistors (IGBTs) are used in high current three-phase AC motors. This application report discusses the theory and requirements of gate-drive power supply for IGBTs. It also discusses the isolation requirements and calculation of correct amount of IGBT drive power. - LM5030 Application: DC - DC Converter Utilizing the Push-Pull TopologyPDF, 329 Кб, Файл опубликован: 21 мар 2007
Серия: LM5030 (4)
- LM5030MM LM5030MM/NOPB LM5030MMX/NOPB LM5030SD/NOPB
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
