Datasheet Texas Instruments REG71050DRVR — Даташит
Серия | REG71050 |
Модель | REG71050DRVR |
60 мА, 5,0 В, понижающий/повышающий зарядный насос в ThinSOT-23 6-WSON от -40 до 85
REG710xx Buck-Boost Charge Pump with up to 60-mA Output Current datasheet
PDF, 1.2 Мб, Версия: H, Файл опубликован: 30 окт 2015
Купить REG71050DRVR на РадиоЛоцман.Цены — от 38 до 251 ₽ 24 предложений от 13 поставщиков IC: PMIC; DC/DC converter; Uin: 2.7÷5.5V; 5VDC; 60mA; WSON6; Ch: 1 | |||
REG71050DRVR Texas Instruments | 38 ₽ | ||
REG71050DRVR Texas Instruments | от 47 ₽ | ||
REG71050DRVR Texas Instruments | от 214 ₽ | ||
REG71050DRVR Texas Instruments | по запросу |
Pin | 6 |
Package Type | DRV |
Industry STD Term | WSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | CFF |
Width (мм) | 2 |
Length (мм) | 2 |
Thickness (мм) | .75 |
Pitch (мм) | .65 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
Iout(Max) | 0.06 A |
Iq(Typ) | 0.065 мА |
Package Group | WSON |
Rating | Catalog |
Special Features | Enable |
Switching Frequency(Max) | 1000 kHz |
Switching Frequency(Min) | 1000 kHz |
Topology | Buck/Boost |
Тип | Charge Pump |
Vin(Max) | 5.5 В |
Vin(Min) | 2.7 В |
Vout(Max) | 5 В |
Vout(Min) | 5 В |
- Optimizing Output Voltage Ripple for the REG710PDF, 56 Кб, Файл опубликован: 10 фев 2003
Many portable power applications require a power source that has buck?boost capability with low output ripple. For this application, the REG710 is a prime choice; however understanding the affects of the pump and output capacitors allows designers to take full advantage of theREG710?s capabilities in order to minimize output voltage ripple.
Серия: REG71050 (7)
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost or Inverting Charge Pump (Inductorless)
